Old 11-01-2016, 18:40   #1 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow Lyf LS-5013, Some issue Inside
Lyf LS-5013 was running slow. So decided to format it with taking user data [Contacts] backup.
But got some problem. Team please see inside..
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 460001154D323237A6D2004215FAE94F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM227
[eMMC] : FLASH_CID : 150100463732324D4200D2A64FE92315
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0xB680A483156A7B028C39FDDBB708ECD7
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : LYF
ProdName  : LS-5013
ProdModel : LS-5013
Device    : LS-5013
AndroidVer: 6.0
MTKxCPU   : MT6735
MTKxPRJ   : LYF-LS-5013-R25
SECURITY :
IMEI_SW [1] : 91150********
IMEI_SW [2] : 91150********
BTMAC Addr  : E2DB******
WiFi MAC    : 000000000000
MODEM :
BaseBand  : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P31_1_lwg_n
EXTRA :
LCD : Not info available :(
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : sp8408_mipi_raw
CAM [1] : s5k5e2ya_mipi_raw
CAM [2] : ov5648_mipi_raw
CAM [3] : gc2355_mipi_raw
MODEM : t93_hct6753_65t_m0-lwg_dsds-_3m_gsm4p_w1_8_fdd3_5_tdd40
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Finish at : [10/31/2016 / 12:55:47 PM]
Operation : Read UserData [ v1.58 ]
PhoneBook : Enabled
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processiung : PhoneBook extraction
Step #1
Error while reading PhoneBook! Code : 0x01 :(
Operation Failed
Elapsed: 00:00:10
PhoneBook : Enabled
PhoneBook : VCFv3 Format output Enabled
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Step #1
Operation Failed
Elapsed: 00:00:09
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:38
Strange after format, phone was in bootloop. So decided to format with wipe option.
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear RDP
Clear Ok!
Done!
Elapsed: 00:00:17
Now phone is OK.
This thread is just to inform/report team whether there is any problem in the format option as the format with first option brings the phone to bootloop and after format with 2nd option it starts...
Please check this issue, also the User data backup problem..
Thank you...
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 11-01-2016, 18:43   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Device have, seems, enabled encryption of userdata. In that case need use wipe. Phone will format and decrypt all fast itself. In first case - it can took muuuch time.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-01-2016, 19:20   #3 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow
Originally Posted by JayDi View Post
Hello.
Okay got it.
But, There is no way to recover data from it if device is encrypted.??
Old 11-01-2016, 19:51   #4 (permalink)
JayDi's Avatar
Member: 462970
Decryption price ( just a power/electricity/time ) not cover even hundred new devices cost.
Page generated in 0.20141 seconds with 8 queries
