Old 01-11-2010, 13:40   #1 (permalink)
Member: 243167
Thanks Meter: 14
China Nokia 5330 Firmware required
Any Body send to me a firmware of this model: China Nokia 5330
its firmware name is not present so i send picture of this phone kindly see it and give me file As Soon As Possible.
http://rapidshare.com/files/33363486..._5330.rar.html
Old 01-11-2010, 17:08   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we can advice you a flash file after you post here log of "Read detailed information"
also, let us know what problem do you have with your phone and have you tried to solve it by format FFS?
Old 01-12-2010, 19:17   #3 (permalink)
Member: 243167
Thanks Meter: 14
Sir,
it cannot ok after format ffs coz it alredy erase whole chip no firmware or epprom in this phone and i send it log file iff you required
log here:
==== log opened: [1/11/2010 4:26:04 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] Chinese Miracle v3.05
S/N: 35F6:0112
Wait...
Device: Autodetect 6205-6227 NOR
Done
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [1/11/2010 4:26:19 PM] ====
COM3 [VCP0] selected
module v3.05
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:B203:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01027E02200200:18859F00000000
flash: AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18909F8518909F8518909F8518909F8518909F8518909F85
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100111-163326.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 7 min 27 sec
Remove/Install battery now !
and i send you it currept eprom read file as a link file kindly download and see it
Link here: http://rapidshare.com/files/33427053...6.B0E.rar.html
Thanks
Old 01-12-2010, 21:01   #4 (permalink)
Member: 148515
hello!
what about file which you posted in your first message?
is it faulty file or good one?
Old 01-13-2010, 17:13   #5 (permalink)
Member: 243167
Thanks Meter: 14
no it is only pictures for your guideing .................................................. ...
Old 01-13-2010, 19:04   #6 (permalink)
Member: 148515
hello!
you must open with notepad operation.log file which is located in Chinese Miracle folder.
scrool it from up from end and find First operation with this phone.
there you will see Original software version.
post it here
Old 01-14-2010, 11:29   #7 (permalink)
Member: 243167
Thanks Meter: 14
Yes sir, it is first opration file who i send you already i have recevied this phone in same condition who i send you last post so kindly give me this file and i send you pictures of this phone kindly see it. i send you link kindly download it......
link Here: http://rapidshare.com/files/33363486..._5330.rar.html
Old 01-14-2010, 19:51   #8 (permalink)
Member: 148515
hello!
i can not see in your log phone software version.
sorry, i can not advice any flash file, becuase i dont recognise this phone by picture.
nokia 5800 firmware unlock this model simlock MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 04-09-2010 11:22
want nokia 5330 china pinout .::Dr.Gsm::. Infinity-Box 11 10-31-2009 08:04
Nokia N80 firmware V3.0617.0.6 (UK) required. Ron1 Nokia Base Band 5 ( BB-5 ) 8 06-09-2006 01:22
NOKIA 6310i UPGRADE FIRMWARE REQUIRED doditnt Nokia Digital Core Technology 4 ( DCT-4 ) 14 03-01-2005 21:25
Page generated in 0.21976 seconds with 9 queries
