09-26-2015, 12:21 | #1 (permalink) |
Banned Join Date: Mar 2013 Location: ranipur sindh pakistan
Member: 1905774 Status: Offline Sonork: 100.1646709 Thanks Meter: 972 | MT6571_Qmobile_X2@X6_Factorry File Read Faild_??? Code: Operation : Read Flash [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Not supported FlashType for this operation yet :( Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
09-26-2015, 14:01 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | i9500 nand cpu not read Operation : Read Flash [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00C800BC009000550054007F007F0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009C , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00C8 00BC 0090 0055 0054 007F 007F [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Not supported FlashType for this operation yet Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
09-26-2015, 15:01 | #10 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | ur mxxxxxx tool cant read nand fectory flash .. ask them its possible or not ur mxxxxx tool cant read nand in bin formate also which work perfect with mxxxxx tool or other tool .. try now and urself take working set with NAND chip read file with mxxxxx with any formate bin or scater and try write that file and see what u get in hand and after that post in mxxxxx section they will close thread or delet thread PS: ur mxxxxxxx tool totaly depend on cm2 now |
09-27-2015, 17:32 | #13 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | This NAND BOOT not supported.. [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 Mr. JayDi say here... http://forum.gsmhosting.com/vbb/f296...l#post11307389 Remember.. and no question any more..... Mr. JayDi i trust in you.. keep working for all user of CM2.... |
The Following User Says Thank You to maomatrix For This Useful Post: |
