Old 03-31-2016, 11:20   #1 (permalink)
Member: 2364508
Thanks Meter: 15
Oppo r2001 problem
AFTER FORMAT SET ONLY VIBRATE BY AN OTHER TOOL.
NOW PRE LOADER ERASED.
I ALREADY REPAIR IT VIA CM2 AND SUCCESS FLASH BUT SET WONT ALIVE.
ANY HELP PLEASE.
======= Flash
Files set for flashing :
[ MCU ] : OPPO R2001.bin
Wait for phone...
Phone found! [ 33 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040503A1FF085171
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A1FF085171
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 6EE4FE402E10C7565A6CFBED5DCBC045
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
USBDL : Init HSUSB Ok!
Brand : OPPO
ProdName : OPPO82_13081
ProdModel : R2001
Device : R2001
AndroidVer: 4.2.2
MTKxCPU : MT6582
MTKxPRJ : R2001_11_A.01_141210_L
ISPFF ID : 6582 , TARGET ID : 6582
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write done , 3728 blocks sent
Done!
Elapsed: 00:05:49
Reconnect Power/Cable!
Old 04-01-2016, 06:49   #2 (permalink)
Member: 2364508
Thanks Meter: 15
where is the support ???
Just let me know pre loader erased can be done or not ????
Old 04-01-2016, 08:07   #3 (permalink)
solusi hp's Avatar
Member: 2162000
Sonork: 100.1670061
Thanks Meter: 205
normally if have good backup is enough write with cm2, other way if still dead check in your device manager what status dont press any key in phone if show preloader ........ its mean have preloader or boot file.
Old 04-01-2016, 12:26   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
ANY HELP PLEASE.
======= Flash
Wait for phone...
Phone found! [ 33 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : OPPO
ProdModel : R2001
Device : R2001
AndroidVer: 4.2.2
MTKxCPU : MT6582
Erase Flash now ...
Write Flash now ...
Done!
Elapsed: 00:05:49
didnt u take backup before formatting..?
Old 04-02-2016, 07:01   #5 (permalink)
Member: 2364508
Thanks Meter: 15
Unfortunatly i didnt take backup please some one upload backup taken by cm2.
Old 04-02-2016, 08:12   #6 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
wait for me.. let me check it..
The Following User Says Thank You to LoveLess For This Useful Post:
Old 04-02-2016, 09:41   #7 (permalink)
Member: 2364508
Thanks Meter: 15
thanks for your help i am waiting
Old 04-02-2016, 10:18   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
https://yadi.sk/d/n0xWwQErqgDYs
Old 04-02-2016, 12:08   #9 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
first try with this preloader
The Following User Says Thank You to rehmani For This Useful Post:
Page generated in 0.20912 seconds with 9 queries
