Old 06-30-2008, 05:17   #1 (permalink)
Member: 348774
Thanks Meter: 66
myphone s21 unlock not done
i have here my logs: why myphone s21 after unlock done then insert diffrent sim LCD display "INSERT SIM.
COM7 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: unlock
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6223:8A04]...
CPU: MT6223
high speed boot enabled
chip: 0011:17C1:000C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.99FAA39A.[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_06.BIN_2AB1922D].rpl
identification#1 detection finished
device-id: 99FAA39A
identification#1 protocol ver: 04
ver. sw1: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_06.BIN
ver. sw2: T01_23.07A.W0736.MP.FMCAM-FTP_V0.06, D26D4ED5
ffs offset/size: 00800000/00800000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00CC0000
Detected eeprom/ffs address is non-standard: 00CC0000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00CC0000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00340000
ffs chip: 00
eeprom/ffs area: 00000000:00CC0000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_06.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_06.BIN]_20080629-204517.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_99FAA3 9A_TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0 736_MP_FMCAM-FTP_V0_06.BIN_2AB1922D_20080629-204655.B0X.bin
Finished, time used: 451 sec
Remove/Install battery now !
i've try diffrnt unlock method but LCD display "INSERT SIM"
Old 06-30-2008, 05:26   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
hello brother first full flash with infinity framware than unlock
Old 06-30-2008, 05:35   #3 (permalink)
Member: 348774
Thanks Meter: 66
Sir im new in this support but i can't see any myphone flash file selection
Old 06-30-2008, 16:08   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Backup files received, files will be uploaded in support area and this model will be added ASAP.
Old 07-02-2008, 11:30   #5 (permalink)
Member: 377736
Thanks Meter: 2
Sounds good thanks for that sir,I have 1 waiting....
Old 07-03-2008, 10:59   #6 (permalink)
Member: 130995
Hello,
Here is updated software for MyPhone-S21: http://www.infinity-box.biz/download...dule_v2.26.rar
The Following User Says Thank You to InfinitySupport For This Useful Post:
myphone s21 unlock atlast...... jaburnok Infinity-Box 11 07-31-2009 09:56
myphone S21 unlock in test mmodule 2.32 not done yhob Infinity-Box 0 09-19-2008 12:13
myphone s21 unlock bugs jaburnok Infinity-Box 3 08-17-2008 12:49
MYphone S21 unlock test not done.. yhob Infinity-Box 3 08-15-2008 15:57
MyPhone S21 Unlocked with New MModule 2.27 alfox Infinity-Box 6 08-13-2008 13:18
Page generated in 0.22482 seconds with 9 queries
