09-27-2008, 09:46 | #1 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 73455 Status: Offline Thanks Meter: 23 | 5310 NMM-3 deadset how to flash? action taken: 1. detect pinout on pinfinder 2. open chinese miracle then set flashfile and write.... here's the logs::: COM23 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:4603:0004 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 48 sec Remove/Install battery now ! i would like to ask if after findng pinouts on pinfinder, do i have to disconect the phone's cables from pinfinder? or after finding pinout can i derectly flash the phone? pls give me an idea for this...i got this boxes yesterday and a new user for this box.... |
09-27-2008, 10:29 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Bro do not disconnect cables from phone after you have detected pinouts. First try read flash to determine what fw ver. of you're unit. Based on you're flashing logs phone has hardware problems. Possible flash chip. Try to do this first mildly reheat mtk chip (cpu) and try read phone flash again or flash unit. If still same errors appear. Reheat flash chip. Check first if it is glued because some flash chips are glued. And repeat operation again. If still same errors sad to say flash chip is damaged. b.r. |
The Following User Says Thank You to kungpaoski For This Useful Post: |
09-27-2008, 10:41 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Phils
Member: 331390 Status: Offline Thanks Meter: 434 | @ topnoyze it's a HW matter, try to reheat CPU. software always says FLASH CHIP, but for me I always go with CPU. |
The Following User Says Thank You to 3stanGsm For This Useful Post: |
09-27-2008, 12:41 | #4 (permalink) | |
Member: 73455 Status: Offline Thanks Meter: 23 | Quote:
The Following 2 Users Say Thank You to topnoyze For This Useful Post: |
how to flash e250i | adda2004 | Samsung Flashers, Software, Firmware. | 0 | 03-29-2010 12:26 |
Help !! ....5310 Code Counter Blocked !! how to reset 3/3 counter | N/East Unlocker | Cyclonebox | 2 | 10-07-2009 08:54 |
problem whit nokia 5310 nmm-3 | alssalafiy | Infinity-Box | 6 | 05-07-2009 20:51 |
805SC 3.1 How to flash | saajith | SPT BOX | 3 | 03-02-2009 01:57 |
need pinout 5310 NMM-3 | 99026 | Infinity-Box | 1 | 11-30-2008 12:41 |
