05-18-2011, 14:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: MoviL GsM Age: 38
Member: 949016 Status: Offline Sonork: 161.7672 Thanks Meter: 25 | 8520 Dead after Format FFS J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02 |
05-18-2011, 15:02 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | This firmware is not present on support area. Do you have backup of this phone? If yes then write it back to phone. Else find same model from local market, read full flash and then write it to your faulty phone. Wr. |
05-18-2011, 19:06 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you did not refuse- program had to make EEPROM backup automaticly. find it, load as EEPROM and write to phone. it will be restored to initial state |
05-18-2011, 20:31 | #4 (permalink) |
Member: 949016 Status: Offline Sonork: 161.7672 Thanks Meter: 25 | i did it and dont work still phone dead COM6 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs JINGRAN_PCB01_GPRS_MT6225_S00.A5188V1_0__ffs_20110 517-144712.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\ChineseMiracle\backup_security\id.9 7163342.[J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02.BIN_3BC56D71].rpl ==================== New firmware found (v.3.30, database date: 11.05.2011): J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 97163342 rom info ver: 05 sw version: J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02.BIN project-id: M6225_08A_X510_DFD_53_V02, 716DC53B code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02__ffs... file saved: C:\InfinityBox\ChineseMiracle\J2TECH25_08A_GEMINI_ PCB01_GPRS_MT6225_S00.M6225_08A_X510_DFD_53_V02__f fs_20110518-151442.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... file saved: C:\InfinityBox\ChineseMiracle\backup_security\J2TE CH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08A_X5 10_DFD_53_V02__system_log_97163342_3BC56D71_201105 18-151636.B0X.bin Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\InfinityBox\ChineseMiracle\backup_security\J2TE CH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08A_X5 10_DFD_53_V02__system_log_97163342_3BC56D71_201105 18-152018.B0X.bin Finished, time used: 10 min 18 sec Remove/Install battery now ! |
05-18-2011, 22:00 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you have many eeprom files, choose the first one. file end with numbers "20110517-144712" means date and time 2011 may 17th, 14h47m12s choose the first available |
5110 v 6.0 after unlocking problem with net | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 16:11 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
