Old 04-24-2008, 10:00   #1 (permalink)
Member: 496386
Thanks Meter: 6
ceat p8300 after flash set not ok
sir plz help me ceat p8300 after flash set not ok
here is log
COM1 selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
chip: 0031:5028:C6E9
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80424-123344.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 Ok
security area backup saved: id.A660DDEE.[M108_PCB01_GPRS_MT6226_S01.S518_HW_05C_S518BT.B_ZY ZX_G_V1.1.4.E.G_BUILD_NO.BIN_8847338D].rpl
identification#1 detection finished
device-id: A660DDEE
identification#1 protocol ver: 04
ver. sw1: M108_PCB01_GPRS_MT6226_S01.S518_HW_05C_S518BT.B_ZY ZX_G_V1.1.4.E.G_BUILD_NO.BIN
ver. sw2: S518BT.B_ZYZX_G_V1.1.4.E.G
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
security area#1 calculation
file saved: backup_system_log_A660DDEE_M108_PCB01_GPRS_MT6226_ S01.S518_HW_05C_S518BT.B_ZYZX_G_V1.1.4.E.G_BUILD_N O.BIN_8847338D_20080424-123357.B0X.bin
Area: Firmware
Write: Firmware
Write Done
file saved: backup_system_log_A660DDEE_M108_PCB01_GPRS_MT6226_ S01.S518_HW_05C_S518BT.B_ZYZX_G_V1.1.4.E.G_BUILD_N O.BIN_8847338D_20080424-123406.B0X.bin
Finished, time used: 251 sec
Remove/Install battery now !
but set is not ok plz helpppppppppppppppppppppppppp
Old 04-24-2008, 20:04   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
which flash you used for flashing?
flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Cect-P8100+_M108_PCB01_GPRS_MT6226_S01.S518_HW_05C_S518 BT.B_ZYZX_G_V1.1.4.E.G_BUILD_NO_16m_En_Cn_Hi_Cn_Ar .B0M.bin
i flashed lg b2060 ....after flash set dead..help. Rin2 Infinity-Box 2 03-21-2010 06:01
c160 flash okk different flash file but phone set not ok................ vertex777 UST Pro II 2 11-30-2008 09:22
LG 8330 after flash set not open khokonhajigonj Cruiser Suite 5 06-09-2008 22:28
d500 after flashing set still death solution4mobile UST Pro II 0 02-25-2007 10:09
Page generated in 0.13465 seconds with 9 queries
