Old 11-29-2014, 16:33   #1 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
MTK6582 unsupported
Chinese Miracle II [MTK module] v 1.06
Start at : [11/29/2014 / 7:29:54 AM]
Operation : Check / Read Info [ v1.06 ]
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582|8312_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 8801034E4361726420109C136033B0AF
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C
[NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000
[NAND] : FLASH_LEN : 0x00000000
INT RAM : 0x00000000
EXT RAM : 0x00000000
BOOT TYPE : DONE
SOC VERIFY : 00
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
Old 11-29-2014, 17:24   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Just t2 steps make it supported :
1. Charge battery Fully
2. Not press any key, when connect.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 11-30-2014, 13:01   #3 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
pattern lock how to remove how to read ?
how to make backup flash ?
Card found: S/N 2682:0128
Operation : Read Flash [ v1.06 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0088 , OEM : 0103
[eMMC] : FLASH_INF : draC
[eMMC] : FLASH_CID : 8801034E4361726420109C136033B0AF
[eMMC] : FLASH_LEN : 0x00000001CE100000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
#819 : Data CRC Error : 8200 , 8000
Read error
Operation Failed
Elapsed: 00:00:57
Reconnect Power/Cable!
Operation : Read PatternLock [ v1.06 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:01
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
FS Size : 1023 MiB
Magic Ok
Mount point : /data
PatternLock not set
Done!
Elapsed: 00:00:20
Old 11-30-2014, 13:15   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Seems as phone have still empty battery or something else ( like cable problem / connection problem ).
Patternlock - seems as not set. If phone asks for google account - it not help.
Old 11-30-2014, 16:09   #5 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
batter is almost 40% and set is asking enter password not pattern now what is solution ?
Old 12-01-2014, 07:33   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
As I told - it have not patter.
Password reading is exist, but you need have 2-3 ATI latest video cards to brute it.
Probably - we add it later.
Resetting feature for password is on way, but still need time to finish it.
IF you have week or so - you can wait for update/test exe, if not - only format FFS to reset all.
Old 12-01-2014, 07:34   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Old 12-05-2014, 12:15   #8 (permalink)
Member: 1520712
Thanks Meter: 19
PLEASE help .is any box support vodafone888 cpu mtk6582m mtk6290 lte modem? vodafone smart4.
Page generated in 0.16829 seconds with 8 queries
