Old 04-23-2008, 19:10   #1 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
nokia 2505 CDMA connecting with auto pinfinder ?
can we connect the nokia 2505 CDMA set using infinity auto pinfinder box ?
Old 04-23-2008, 19:23   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sure, connect red and black power wires to battery termminal,
set cable L4A, set data pins 1 & 2.
and use pinfinder as interface.
if 1 & 2 will not work- try to set 2 & 1.
for this we have "swap pins" button
Old 04-23-2008, 19:58   #3 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
is this correct ?
it is not connecting //?
Old 04-23-2008, 20:07   #4 (permalink)
Member: 148515
yes, correct.
for sure Power button must be pressed in program to make phone powerable ON from wires
if not work this way: set 2 : 1
Old 04-24-2008, 05:59   #5 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
yes, correct.
i tried both ways as u said but it did not connect ...
any other hint ?
Old 04-24-2008, 09:57   #6 (permalink)
Member: 148515
hello!
Power lines from box (red & black) must be connected to battery terminals.
can you power On phone from this wires?
Old 04-24-2008, 19:05   #7 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
hello!
yeah i can power on the phone with these wires ..
but it is not connecting with the software ...
Old 04-24-2008, 19:37   #8 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
if u know pinout then just selact pin and press set buttone on teb
thats it
Old 04-24-2008, 20:40   #9 (permalink)
Member: 148515
hello!
with which program are you trying to connect with it?
do you set correct com port there?
Old 04-24-2008, 20:53   #10 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i am trying to connect it with NOkia Original flasher CCS12R033.....
there is no option to select the com port
Old 04-24-2008, 21:08   #11 (permalink)
Member: 148515
hello!
this is a reason of your problem.
you must find where is com port settings in this program
Old 04-24-2008, 21:10   #12 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
hello!
there is no com port setting in that program it detects the com port automatically ..
Old 04-25-2008, 08:15   #13 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
then set u r infinity box port to com 1
like this
Old 04-25-2008, 08:35   #14 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
like this
i did as u said but it did not connect ...
Old 04-25-2008, 09:45   #15 (permalink)
Member: 148515
hello!
might be its checking only physical com ports, not usb
nokia 1325 cdma connect in pinfinder Imrankhan Infinity-Box 7 02-18-2011 00:24
need Flash File Of Nokia 2505 CDMA turumen Nokia CDMA 4 03-22-2010 11:20
Please help me unlock this nokia 2505 cdma balak400 Nokia CDMA 2 12-08-2009 00:23
nokia 2505 cdma display blink omkarvitekar Infinity-Box 2 12-19-2008 19:53
how can i find kp130 pinout with auto pinfinder plz help omer100 Infinity-Box 21 07-11-2008 11:31
Page generated in 0.21187 seconds with 10 queries
