Old 08-06-2008, 14:10   #1 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
nokia 1325 cdma connect in pinfinder
software version: 1.14
cable type: HF 4 pin (L4A)
platform: MSM: Qualcomm CDMA, 3G
searching adapter at COM3...
adapter found, version: 2000
pins: 4, plain
power cycles: 1
activation cycles: 5
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Phone should be Powered-On !
Power-On phone now and press "Ok"
Be sure that phone is not in sleep mode during pinout detection !
Press any phone key from time to time to wake-up phone.
detecting pins...
detected baudrate: 115200
result: Rx:1 Tx:4
time required: 5 sec
Power On !
The Following User Says Thank You to Imrankhan For This Useful Post:
Old 08-06-2008, 15:12   #2 (permalink)
Member: 128745
Thanks Meter: 16,937
thankyou for the test result
Old 08-23-2008, 06:54   #3 (permalink)
torpedo_seluler's Avatar
Member: 368629
Thanks Meter: 87
Did infinity support flashing this model??
Old 08-23-2008, 07:36   #4 (permalink)
Member: 130995
Thanks Meter: 35,228
This function is not supported yet.
Old 09-14-2008, 12:51   #5 (permalink)
EMOTION BBSR's Avatar
Member: 194285
Thanks Meter: 53
my pinfinder showing this
pins: 4, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
result: Rx:3 Tx:4
time required: 20 sec
Power On !
Old 09-22-2008, 22:31   #6 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i am unable to connect this set with pinfinder as each and everytime it shows different pins ..
Old 09-23-2008, 08:20   #7 (permalink)
Member: 130995
Hello,
Please, use manual pin selection for this model.
Old 02-18-2011, 00:24   #8 (permalink)
Member: 330758
Thanks Meter: 12
Lightbulb nokia 1325
what module use please......
error in connection in nokia sets HUM Nokia Hardware & Hardware Repair 14 01-09-2015 07:36
~~ Nokia 1325 ORIGINAL_FLASHER & flash file~~ king_of_rajasthan Nokia CDMA 25 08-14-2011 12:45
problem in nokia 1325 ranagaurav Nokia Hardware & Hardware Repair 1 07-22-2009 18:37
nokia 2505 CDMA connecting with auto pinfinder ? gsmsikar Infinity-Box 22 03-04-2009 15:31
n68 connects with pinfinder,but cant connect in chinese miracle GOODNESS Infinity-Box 13 07-24-2008 21:33
Page generated in 0.22119 seconds with 9 queries
