Old 02-15-2011, 06:05   #1 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
strange error in micromax x360
when i m flashing x360 i m getting this error. set history hangs after 3 mins.
here is the logs
COM9 [VCP0] selected
module v3.62
Device: Micromax-X360
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
Micromax-X360_TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808 _PR1_V9_0_INDIA_2009-12-11_En.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:940F:000F
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:09EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
rom info detection finished
rom info ver: 07
sw version: TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808_PR1_ V9_0_INDIA.BIN
project-id: E808_PR1_V9.0_India, 00000000
code offset: 00020000
ffs offset/size [01]: 00E00000/001F0000
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
security area (sec info, hash) size is incorrect: FFFFFFFF
security area (sec info, cust) can not be unpacked
product id: ?
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Micromax-X360_TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808 _PR1_V9_0_INDIA__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Micromax-X360_TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808 _PR1_V9_0_INDIA__ffs_20110215-102055.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is present: 00020000
rom info relocation detected
startup code area #1 check...
done
Area: Firmware
Write: Firmware
security area (sec info, cust) calculation...
identification header detected
error: relocation table offset is unknown
error: jump table is not found or incorrect, can't detect customization version
error: can't calculate security area (sec info, cust), existing data will be used
Check support area for updates !
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808_PR1_ V9_0_INDIA.BIN
use default security area (sec info, hash) pattern
error: can't assign default hash address range for ffs 00E00000/00003FA0
error: security area (sec info, hash) size is too small: 0000
error: can't calculate security area (sec info, hash)
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 8 min 57 sec
Remove/Install battery now !
Old 02-15-2011, 06:06   #2 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
team please help me how to solve this error .............
Old 02-15-2011, 21:05   #3 (permalink)
Member: 148515
Thanks Meter: 19,536
hello!
try with latest MModule available on support site
Old 02-16-2011, 04:38   #4 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
hello!
i tried with latest module but same problem
Old 02-17-2011, 21:27   #5 (permalink)
Member: 1043909
Thanks Meter: 60,972
Please, try to use ChineseMiracle software for this phone, everything should be done without any problems.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
Page generated in 0.18037 seconds with 9 queries
