12-15-2008, 10:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Punjab Pakistan
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | Nokia n82 copy hear is log COM7 [VCP0] selected module v2.71 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CD03:000A boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.6438D47F.[TOP25_06B_PCB01_GPRS_MT6225_S00.24D_SN_OV_T_B_F_U_ 2506B_V_0_18.BIN_2E180BB4].rpl identification#1 detection finished device-id: 6438D47F identification#1 protocol ver: 04 ver. sw 1: TOP25_06B_PCB01_GPRS_MT6225_S00.24D_SN_OV_T_B_F_U_ 2506B_V_0_18.BIN ver. sw 2: 24D_SN_OV_T_B_F_U_2506B_V_0_18, 4BF4E7D1 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00790000 Detected eeprom/ffs address is non-standard: 00790000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_6438D47F_TOP25_06B_PCB01_GPRS_MT6225_S00 .24D_SN_OV_T_B_F_U_2506B_V_0_18.BIN_2E180BB4_20081 215-135621.B0X.bin Finished, time used: 139 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-15-2008, 22:20 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! are you sure that this is phone's original version? TOP25_06B_PCB01_GPRS_MT6225_S00.24D_SN_OV_T_B_F_U_ 2506B_V_0_18 you can check this in operation log, look for first format operation |
12-16-2008, 19:56 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flash phone by this fiie: flashfiles/ChineseMiracle/_MT6225/TOP25_06B_PCB01_GPRS_MT6225_S00.24D_SN_OV_T_B_F_U_ 2506B_V_0_18__NOKIA_N82_COPY_16m_En_Ru_Fr_It_De_Th _Vn_Tr_Ar.B0M.bin and make format FFS complete after |
12-17-2008, 06:18 | #5 (permalink) |
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00790000 Detected eeprom/ffs address is non-standard: 00790000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation it will give this error |
12-17-2008, 19:45 | #6 (permalink) | |
Please, explain what is not clear in given instruction and we will try to explain it better. | |
12-18-2008, 06:47 | #7 (permalink) |
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | set is in flight mode i have made complete format .in formate when soft is reading eeprom he said ffs eeprom address is non-standard press yes to make standard ar no to repeart this opreation again i am press yes after this set is dead i have flash with this file TOP25_06B_PCB01_GPRS_MT6225_S00.24D_SN_OV_T_B_F_U_ 2506B_V_0_18__NOKIA_N82_COPY_16m_En_Ru_Fr_It_De_Th _Vn_Tr_Ar.B0M after flashing set is ok but lcd is black to light no logo after flash i have done again format but same not standrad addres prs yes to make standred r no to repeart again |
12-18-2008, 19:54 | #8 (permalink) | |
Please, check instruction in log one more time, it was given an advice to read full flash for emergency case. Now you must flash phone with other firmware that has support for your phone LCD hardware type. | |
12-21-2008, 05:48 | #9 (permalink) | |
Freak Poster Join Date: Nov 2008 Age: 43
Member: 904326 Status: Offline Thanks Meter: 62 | Quote:
but there is only 1 file in support area hows to know any other files???????????? | |
12-21-2008, 10:28 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You need to find file with version similar (not exact but similar) to this version: TOP25_06B_PCB01_GPRS_MT6225_S00.24D_SN_OV_T_B_F_U_ 2506B_V_0_18 |
12-22-2008, 07:03 | #11 (permalink) | |
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | Quote:
hope i m right it is the right firmware ver(MT6225_S00.24D) what u say there is nothing match any other files | |
12-22-2008, 16:42 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you can try this one: flashfiles/ChineseMiracle/_MT6225/TOP25_06B_PCB01_GPRS_MT6225_S00.206_OV_T_B_F_U_250 6B_V_0_5_FLG3_16m_En_Ru_Fr_De_Farsi_Pt_Ar.B0M.bin |
12-22-2008, 16:43 | #13 (permalink) |
12-23-2008, 07:36 | #14 (permalink) |
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | TOP25_06B_PCB01_GPRS_MT6225_S00.24D_SN_OV_T_B_F_U_ 2506B_V_0_18 thxxxxxxxxxxxxxxxxxx problem was solved with this flash file any many tries .flash again flash and again and done |
No route preview - Nokia Maps 2.0 - Nokia N82 | krooooolik | GPS devices , Navigators & Maps | 0 | 02-18-2009 14:33 |
N82 copy original 1 sim pinout PLZ | meisam | Infinity-Box | 7 | 11-19-2008 13:29 |
Nokia 6280 - copy protected file | radeck | Nokia Multimedia | 7 | 08-12-2007 07:47 |
nokia ngage copy protection | hikaru | Nokia Multimedia | 87 | 07-02-2004 18:49 |
