11-16-2008, 11:06 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | N82 copy original 1 sim pinout PLZ Looked through the forum but none of pinouts here fit my phone.It's just like original Nokia N82,it has usb interface just like original N82.Even has pins like original FBUS pins. Anybody has pinouts for this phone? |
11-16-2008, 15:22 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post connector type. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
11-16-2008, 15:34 | #3 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | Yes exactly got the same message : "language set: english" Connector type is Nokia CA-101 Not sure about chinese corresponding name L14A or L5B |
11-16-2008, 15:41 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i never met this phone before, so cant tell exactly where is tx/rx but i can teach you how to find needed pins in 5minutes using just multimeter |
11-16-2008, 23:00 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
plz help n96 copy original how can format with spider | yarra | SpiderMan | 2 | 05-03-2009 12:37 |
Nokia n82 copy | gsmkiller173 | Infinity-Box | 13 | 12-23-2008 07:36 |
N95 1 sim pinout help | Felix_Ponsel | Chinese Models & Cloned Phones | 1 | 10-12-2008 09:15 |
new n95 1 sim pinouts | foxthemene | Infinity-Box | 0 | 03-22-2008 17:53 |
Team i Need Urgant Pinout Dual Sim A666 Plz | brain00000 | Infinity-Box | 8 | 11-10-2007 02:45 |
