08-06-2009, 15:49 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 241452 Status: Offline Thanks Meter: 36 | pin finder problem |
08-06-2009, 19:19 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | i think first u should read manuals carefully and check where the problem lies.what kind of phones have u tried with pinfinder? if u still find problems than only ur reseller can help u. |
08-06-2009, 19:40 | #3 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 476420 Status: Offline Sonork: 100.1605239 Thanks Meter: 164 | bro try with small exenple take a phone at hand its better sagem 220 and open PIN FINDER program after try to fiend pinout maneal to konw what is the problem exactly |
08-06-2009, 20:02 | #4 (permalink) | |
Did you checked voltage at pin-1 of your Unibox (Unibox but not PinFinder). What is voltage value ? | |
10-05-2009, 19:49 | #7 (permalink) |
Major Poster Join Date: Jul 2008
Member: 812109 Status: Offline Thanks Meter: 0 | compaņeros, tengo un problema PinFinder com, no me conecta los C902, C1000 y los q Tienen el PIN 1x5 tampoco, ya hice la modificacion en la infinitud y ya me bota los 5v, que mas puedo hacer? |
10-10-2009, 04:10 | #9 (permalink) |
Member: 812109 Status: Offline Thanks Meter: 0 | Do colleagues, I have a problem with PinFinder, the C902 not connected me, C1000 and the q have the 1 x 5 PIN nor, very few models q recognized me some if but most do not, I made the modification in the infinity and already boot me the 5v, already change the cables that connect both boxes that more can I do? |
10-10-2009, 10:12 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! before searching pinout you must do 3 easy steps: 1. Make sure that this is mt62xx MCU based phone. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx. Now activate Silent mode in phone by pressing and holding "#". 2. Count number of pins in system connector. After this is done- pick correspondent cable. For example if you counted 2x6 pins- it is in total 12 so no point to put L14D cable instead of correct one, L12B. 3. Select cable type, connect power crocodiles in the place of battery. push "Power On!" in software. Now phone is powered with pinfinder power. Try to switch it On. This is main rule for success pinout search. (Phone must turn ON) if all this steps are done, but pinout can not be found even with "activation tries" set to maximumu (20)- then you must look for test points on PCB. this phone do not hold Tx/Rx in system connector |
Infinity Pin Finder Problem....?? | srini.unique | Infinity-Box | 5 | 06-11-2008 22:08 |
pin finder problem ... | BoOzer665 | Infinity-Box | 2 | 06-04-2008 21:14 |
Pin Finder Problem Installtion | Mansoor | Infinity-Box | 1 | 05-12-2008 09:44 |
pin finder problem | srini.unique | Infinity-Box | 1 | 03-17-2008 12:14 |
strange pin finder problem | sandeephanda78 | Infinity-Box | 9 | 02-29-2008 11:56 |
