04-28-2009, 08:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | problem with infinity shell when i run it always says i need download update.. i download update and run it then when i look at shell again says download same modules.. i look at the modules and they are all up to date... its a pain... how can i sort it? |
04-30-2009, 19:14 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, This problem may be a result of incorrect installation. Probably you have moved modules in other folders after installation of Shell located in wrong folder. If you can not check support area manually for updates but you want to check updates via Shell I suggest you to uninstall Infinity-Box software and then install it again. |
Problem with MultiBox Shell | balar | Multi-Box | 3 | 01-14-2010 11:13 |
Small Problem with Latest SHELL | 3stanGsm | Z3X-Team Products | 1 | 11-16-2009 12:58 |
Problem with new shell update 3.1, firmware 2.1 | jands | Z3X-Team Products | 2 | 11-15-2009 19:03 |
Problem Launching Infinity Shell | kasamiko | Infinity-Box | 4 | 04-01-2009 05:29 |
Problem with Infinity SN Reader!! | galaxi | Infinity-Box | 3 | 04-03-2005 03:54 |
