01-24-2009, 15:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | OT-V212 Unlocked Success" module v1.30 Device: Alcatel-V212 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-V212_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-V212_eeprom_calibration-1_20090124-192926.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 79 sec Remove/Install battery now ! |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
01-24-2009, 18:58 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @..::Angel::.. Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-26-2009, 12:32 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: WITH SOME SELFISH PEOPLE
Member: 294880 Status: Offline Sonork: 100.1587133 Thanks Meter: 132 | unlock done ALCATEL OT_V212 COM14 [VCP0] selected module v1.30 Device: Alcatel-V212 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-V212_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-V212_eeprom_calibration-1_20090126-161156.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 91 sec Remove/Install battery now ! |
The Following User Says Thank You to saqibmalik For This Useful Post: |
08-18-2009, 07:56 | #6 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | here is your place for successfull stories http://forum.gsmhosting.com/vbb/showthread.php?t=725574 |
The Following User Says Thank You to shahzaadbutt For This Useful Post: |
08-18-2009, 19:57 | #7 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
re:alcatel ot-s120 and v212 unlock | ndugwaez | Alcatel TCL Phones and New Models | 4 | 07-25-2010 19:03 |
unlock alcatel ot-v212 [ANSWERED] | hippolyte85 | PolarBox 3 | 5 | 05-11-2010 09:31 |
re:alcatel ot v212, ot s120[ANSWERED] | ndugwaez | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 02-25-2010 13:24 |
ot v212 and new ot 103 | btcoolmi | Alcatel TCL Phones and New Models | 0 | 02-24-2010 14:58 |
Ot-v212 Unlock ? | DYNET | Alcatel TCL Phones and New Models | 11 | 01-11-2010 07:10 |
