01-04-2008, 10:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Problem After Formatting FFS Take Care ENJOY |
01-04-2008, 15:02 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what is your phone original software version? please post here, maybe i advice you some other file to try also after you formated FFS- did you hold power button long enough? 30-40sec? |
01-04-2008, 15:16 | #3 (permalink) |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | here is the detail info of the Fone. Device: Autodetect 6205-6227,6228 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished device-id: CC1965E5 protocol ver: 04 ver. sw1: E553_Y12ARTF2_E553_GPRS_MT6226_S01.K789+_01_1.BIN ver. sw2: K789+.E553_Y12ARTF2.01.1 ffs offset/size: 00800000/001FF000 warning: invalid identification, ask/rpl calculation reqired Probably identification data damaged, device id: CC1965E5 firmware version: E553_Y12ARTF2_E553_GPRS_MT6226_S01.K789+_01_1.BIN_ EA051DBC RPL file must be in folder: C:\Program Files\InfinityBox\ChineseMiracle\ You can create RPL from ASK via client/server right now and press YES. Do you want to write RPL file now ? flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: rpl rpl write ok detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... .............. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. . detect standard fat offset pass #1... detect standard fat data... layout detection complete eeprom element #1 detected ok Finished, time used: 137 sec Remove/Install battery now ! Take Care ENJOY |
01-04-2008, 19:20 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! worth to try this one: flashfiles/ChineseMiracle/ZTC-ZT/ZTC-ZT588_E553_Y12ARTF2_E553_GPRS_MT6226_S01.K789+_01_ 1_16m_Ru_Fr_En_Th_Vn_Cn_Hi_Cn_Ar.B0M.bin |
01-05-2008, 12:34 | #5 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
i flashed the fone with >>>>> ZTC-ZT588_E553_Y12ARTF2_E553_GPRS_MT6226_S01.K789+_01_ 1_16m_Ru_Fr_En_Th_Vn_Cn_Hi_Cn_Ar.B0M.bin <<<<< Phone power on Ok Take Care ENJOY | |
n73 2nd sim problem even after format ffs | sorinm | Infinity-Box | 3 | 02-02-2008 20:32 |
CECT T689 After format FFS work only with 1 sim | snsoftkiller | Infinity-Box | 12 | 11-04-2007 21:40 |
After format ffs kg300 dead | Y2ksalman | Infinity-Box | 3 | 10-04-2007 16:21 |
chinese miracle phone after format ffs dead | taleb_nazari | Infinity-Box | 5 | 09-24-2007 08:47 |
