01-25-2010, 15:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: ALGERIA
Member: 447187 Status: Offline Thanks Meter: 107 | probleme unlock 303x after unlock phone blink and after repair security area phone locked Code: COM5 [VCP0] selected module v3.02 Device: Alcatel-303X, 303A Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:858A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.0B4E8793.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_6483DA11].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 0B4E8793 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 11DA8364 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16G provider: 303X-2BMSUA1 customization: CI16CS13 customization: XI16CS13 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CI16CS13 customization: CI16CS13 flash: 98004900000002:2BEA0000000000 flash: 98004900000002:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98004900000002:2BEA0000000000 flash: 98004900000002:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98004900000002:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-303X,303A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_0B4E8793_6483DA11_20091125-150201.B0X.bin Finished, time used: 2 min 34 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-25-2010, 15:24 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There is a problems with some types of new Alcatel phones, it can not be unlocked yet. We are working now to solve this problem ASAP. |
problem unlocking kp500q telcel | cellshop2 | Z3X-Team Products | 2 | 03-29-2010 22:10 |
problem unlock alcatel ot 303x ..... [ANSWERED] | kakaomar | PolarBox 3 | 4 | 02-05-2010 13:32 |
problem unlocking - problem solved :) | chachlar | Universalbox | 7 | 12-10-2009 00:42 |
Problem Unlock with 6210N -> problem solved | d_veras | Universalbox | 6 | 07-05-2009 09:16 |
BIG problem unlocking a 6131 !!! HUGE PROBLEM !!! | humbedj | UID - Box | 9 | 10-13-2007 00:20 |
