Old 08-12-2008, 12:54   #1 (permalink)
omer100's Avatar
Member: 713533
Thanks Meter: 18
problum unlock ot s-520
infinity support when i go to unlock s520 and press service software saying
Read manual from support area ! where is that manual sir
The Following User Says Thank You to omer100 For This Useful Post:
Old 08-12-2008, 13:43   #2 (permalink)
omer100's Avatar
Member: 713533
Thanks Meter: 18
and which cable or pinout to use thanx
Old 08-12-2008, 15:13   #3 (permalink)
omer100's Avatar
Member: 713533
Thanks Meter: 18
i try to flash with all instructions but phone is still asking for network key i download file from support but ph still locked what could be happen sir?
Old 08-12-2008, 16:05   #4 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
similer cables
Cable name: Alcatel-OT-C701
1 2 3 4 5
6 7 8 9
2: Gnd
3: Phone Tx (RJ45 pin 3)
4: Phone Rx (RJ45 pin 2)
Similar cables:
Alcatel ELLE-N3
Alcatel LAVA
Alcatel Mandarina-Duck
Alcatel OT-C700A
Alcatel OT-C700X
Alcatel OT-C701
Alcatel OT-C701A
Alcatel OT-C701X
Alcatel OT-C707
Alcatel OT-C707A
Alcatel OT-C707X
Alcatel OT-C717
Alcatel OT-C717A
Alcatel OT-C717X
Alcatel OT-C820
Alcatel OT-C820A
Alcatel OT-C820X
Alcatel OT-C825
Alcatel OT-C825A
Alcatel OT-C825X
Alcatel OT-C826
Alcatel OT-S520
Alcatel OT-V770X
& the manual is the same as other ALCATEL MTK SERIES; check manual in support erea:
How_to_unlock_flash_Alcatel-c700_c701_c717_c825_etc.txt
unlocked flash will uploaded to support asap
Old 08-12-2008, 16:51   #5 (permalink)
omer100's Avatar
Member: 713533
Thanks Meter: 18
here r logs for unlocking but not done
COM8 [VCP0] selected
Device: Alcatel-OT-S520
Checking data, wait...
Action: write NOR flash
"smart write" active
write:
skip:
skip:
skip:
enhanced security fix enabled
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
chip: 0001:E903:A00E
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22442200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.E0A0D C2E.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_B8A8FFD4].rpl
identification#1 detection finished
device-id: E0A0DC2E
identification#1 protocol ver: 05
ver. sw1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw2: MAUI.06B.W07.28.SP1.V34, 2B005747
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
original imei: 35198902008193
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
security area#1 calculation...
done
file saved: C:\Program Files\InfinityBox\MModule\system_log_E0A0DC2E_JRD2 5_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V3 4.BIN_B8A8FFD4_20080812-164759.B0X.bin
Area:
security area#3 calculation...
customization: CD44DA05
done
Write: security area#3
security area#3 calculation done
security area#2 calculation...
..................counter: 01
done
Write: security area#2
security area#2 calculation done
Write Done
Finalization...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\system_log_E0A0DC2E_JRD2 5_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V3 4.BIN_B8A8FFD4_20080812-165016.B0X.bin
Finished, time used: 177 sec
Remove/Install battery now !
Old 08-12-2008, 17:17   #6 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
pls read carefully my post; you can't unlockit with direct unlock.
Old 08-12-2008, 17:34   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
@omer100
S520 unlock is not supported yet due to we do not have unlocked S520 files yet.
We are working in this direction and hope on good results soon
Old 08-12-2008, 18:43   #8 (permalink)
omer100's Avatar
Member: 713533
Thanks Meter: 18
thanx we will look forwerd for unlocking
Old 10-19-2008, 16:00   #9 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
now sim free flash files are available in support area for alcatel ot-s520 thnx infinity team good work
br
yasermalik
Old 12-05-2008, 16:01   #10 (permalink)
07heaven's Avatar
Member: 57937
Thanks Meter: 34
Should the cable for the C825 (Cable that plugs into mini USB style connector) work with the S520?
Cause I keep trying it and the phone keeps powering on and software does not respond
and is the C825 cable same as S210?
Old 12-05-2008, 17:58   #11 (permalink)
Member: 130995
C825 cable should work for S520.
Just check pinouts in Infinity-Box Shell and you will see the difference in 1x5 and 2x5 connectors.
Is it so hard to compare pinouts in Shell ?
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable: http:///vbb/showthread.php?t=342807
is it possibel to unlock nokia sl3 phpossibel to unlock noones 6600s 520 5130 etc ??? gurnek66@hotmai Genie Universal 4 07-25-2009 12:51
is it possibel to unlock nokia sl3 phpossibel to unlock noones 6600s 520 5130 etc ??? gurnek66@hotmai Genie Universal 1 07-20-2009 12:56
ot s-520 flashing done omer100 Infinity-Box 3 10-13-2008 22:35
Unlock 6150 v 520 MagicSide Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-25-1999 21:38
About unlocking of new 520,920 and 930 Tomas Motorola Old Legacy (EMMI) 8 09-13-1999 02:35
Page generated in 0.23714 seconds with 9 queries
