Old 05-02-2012, 14:28   #1 (permalink)
Member: 747386
Thanks Meter: 30
q mobile e 900 dead after flash
hello mat
q mobile e 900 touch problem i format but same first i make backup then i flash with backup file mobile is not on before this opration mobile is on now mobile not on please help
here log
COM5 [VCP0] selected
module v4.12
Device: _Autodetect MT6228-6268 NAND
Checking data, wait...
Action: write flash NAND
write: Firmware
TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12__firmware_20110917-152628.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930_MP_F1_PK_ BB5E_V34_12.bi
nfi area detection (3 cores) finished: Ok
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (460800)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: E930_MP_F1_PK_V34_07
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930_MP_F1_PK_ V34_07.bin
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
startup code area #1 is invalid
startup code area #1 detection done
rom info ver: 07
sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_V 34_07.BIN
project-id: E930_MP_F1_PK_V34_07, 85120C21
code offset: 00000000
ffs offset/size [01]: 02000000/02000000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
startup code area #1 check...
rpl file not found: c:\InfinityBox\MModule\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12.BIN_CE267B07].rpl
rpl file not found: c:\InfinityBox\MModule\id.00006235._TINNO35_09A_PC B01_GPRS_MT6235B_S01.E930_MP_F1_PK_BB5E_V34_12.BIN _CE267B07_.rpl
rpl file not found: c:\InfinityBox\MModule\backup_security\id.00006235 .[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12.BIN_CE267B07].rpl
rpl file not found: c:\InfinityBox\MModule\backup_security\id.00006235 ._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK _BB5E_V34_12.BIN_CE267B07_.rpl
warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12.BIN_CE267B07
Unknown firmware found (v.4.12, database date: 21.02.2012), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 14 min 46 sec
Remove/Install battery now !
Old 05-03-2012, 21:40   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
post this firmware, i will convert it for you
Old 05-04-2012, 08:57   #3 (permalink)
Member: 747386
Thanks Meter: 30
hello!
here is backup flash file
TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_V 34_07__firmware_20120502-173021.B4M.bin
Old 05-04-2012, 21:27   #4 (permalink)
Member: 148515
hello!
you must upload it to some file hosting service or send it via email to [email protected]
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
PERMANENT MOBILE PHONE SUPPLIER NEEDED MILLENNIUM-INTERNATIONAL Wanted Products 0 08-28-1999 21:23
Page generated in 0.15204 seconds with 9 queries
