01-02-2018, 06:18 | #1 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | redmi note 4x qcomm msm8953 , reply pls . happy new year to all. my phone is mi note 4x qcomm msm8953. phone is user lock. how remove ? phone info : Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 179817A3 ID_BLOCK_L : BBE46743E9F820730256E2A539A5557A ID_BLOCK_L : 609CD64D80ABBB736CFF140F68DE0A7F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Brand : xiaomi ProdName : mido ProdModel : Redmi Note 4X Device : mido AndroidVer: 6.0.1 Manufact. : Xiaomi SysPatch : MMB29M DevComTime: 12/28/2016 3:35:32 AM QLMxCPU : MSM8953 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:23 Reconnect Power/Cable! need help for remove user lock. pls reply. thanks with best regards, mahir |
01-02-2018, 08:31 | #2 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Quote:
01-02-2018, 13:24 | #3 (permalink) |
Member: 1128573 Status: Offline Thanks Meter: 242 | no luck failed user loack removed. OP log is here : Operation : Reset UserLocks [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 179817A3 ID_BLOCK_L : BBE46743E9F820730256E2A539A5557A ID_BLOCK_L : 609CD64D80ABBB736CFF140F68DE0A7F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! ERROR : FS verification fail! Encrypted or damaged! Reconnect Power/Cable! pls. reply . thanks again mahir |
02-27-2018, 16:50 | #8 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | hello I need same problem ... but I dont conect phone with pc... I try vol - + vol + both push... and power... nothing. I made some edl cable....nothing. some ideeas ? Br mihnea |
02-27-2018, 18:16 | #9 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 200 | Quote:
https://androidfilebox.com/tips/edl-...redmi-note-4x/ | |
The Following User Says Thank You to vasko_bojilov For This Useful Post: |
