Old 10-10-2009, 14:15   #1 (permalink)
Member: 387460
Thanks Meter: 13
Rx tx option ?
I need to use rx tx in infinity box.
I dont know that what cable option to select in pin finder.
Or pin finder requird or not in rx tx opration....
Old 10-10-2009, 20:14   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
if u can explain more help will b more easier.check here might help
http://forum.gsmhosting.com/vbb/showthread.php?t=526956
Old 10-10-2009, 21:43   #3 (permalink)
Member: 130995
Thanks Meter: 35,228
Hello,
Please, download PinFinder manual: http://www.infinity-box.com/download..._PinFinder.pdf
You can see detailed instruction.
In case of any problems, please, explain the problem little bit more detailed.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-11-2009, 09:14   #4 (permalink)
Member: 387460
Thanks Meter: 13
like L12B L10A L10B........................
WHAT CABLE OPTION TO SELECT IN PINFINDER CABLE SELECTER SCREEN
Old 10-11-2009, 11:19   #5 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
first compare phone connector with cables u have.when u have perfect cable for phone select same in pinfinder software
Old 10-11-2009, 11:47   #6 (permalink)
Member: 387460
Thanks Meter: 13
With l12a cable u can see rx tx;;;;;;;;;but waht is the name of rx tx cable
example if i have l12b cable then i will select l12b in pin finder list.......
Thats y i upload image of pin finder cable selicting pic**************
Old 10-11-2009, 11:48   #7 (permalink)
Member: 387460
Thanks Meter: 13
Sorry for bad english
Old 10-11-2009, 11:49   #8 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
post connector type in phone
Old 10-11-2009, 11:51   #9 (permalink)
Member: 387460
Thanks Meter: 13
Rx tx cable name ?????????????
What is the name dude?????????????????
Old 10-11-2009, 20:45   #10 (permalink)
Member: 130995
how many pins in your phone connector ?
is it 1x5 pins or 1x18 pin or 2x6 pins or ... ?
Old 10-14-2009, 08:40   #11 (permalink)
Member: 387460
Thanks Meter: 13
cable is damage only option is rx tx
Old 10-14-2009, 21:23   #12 (permalink)
Member: 130995
Hello,
Old 10-15-2009, 12:01   #13 (permalink)
Member: 387460
Thanks Meter: 13
ok i have nokia 1112 china and have J-TAG AND PINFINDER RX TX CABLE
BUT DONT NO HOW TO CONNECT
Old 10-15-2009, 14:20   #14 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
solder wires on testpoints given on pcb(any wire at any point from rx-tx pinfinder cable) make search in pinfinder software.pinouts will b defined and u can perform desired operation
Old 10-16-2009, 11:49   #15 (permalink)
Member: 130995
1. use PinFinder cable with open wires
2. solder any wires to test-points
3. select "24 pin" cable in PinFinder software and make pinout detection in automatic mode
UniBox schematic, Led on RX, TX need. IceKiller ZLIN Hardware Equipments for GSM 2 05-30-2003 21:54
rx/tx switch 0505 ? sjakie Nokia Hardware & Hardware Repair 5 05-22-2003 05:35
rx tx machine mohammed Hardware Repair by brands 2 11-12-2002 02:55
power & rx- tx calibration baraka42 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-03-2002 07:08
Hardware for RX/TX-Tuning Deppe92 Hardware Repair Item Wanted 1 04-25-2002 04:35
Page generated in 0.23735 seconds with 10 queries
