11-28-2006, 17:12 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 47
Member: 145241 Status: Offline Thanks Meter: 26 | S-500 unlocking problem Device: Spice S500 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6205:8B00]... Release Power button now ! Boot Done Initialize... detecting chip[01]... Flash: DA2210DD00DD02 Flash: 18E59F00000000 flash: not detected Initialize Fail Finished, time used: 14 sec pl.check & tell me whats the problem thanks |
11-29-2006, 07:54 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Quote: | |
11-29-2006, 12:41 | #8 (permalink) | |
Please, download MModule v1.19 from support area "beta/test software" section and try to unlock your phone again. Make backup before unlock please. Waiting for your results ! | |
11-29-2006, 13:42 | #9 (permalink) |
Member: 145241 Status: Offline Thanks Meter: 26 | S-500 unlocking fine in inifinity-box hello infinity support u r great yours mmodule v1.19 working fine without any problem. working ok 1000000000000000000000000000000000% thanks for great support. |
12-16-2006, 09:26 | #11 (permalink) | |
the problem can be in cable. see here phone pinout: http://forum.gsmhosting.com/vbb/show...59&postcount=7 here is box description: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 if no connection - try to change rx <-> tx | |
12-19-2006, 08:21 | #12 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 237210 Status: Offline Thanks Meter: 90 | still not conected hi infinity, i tried all possible combination like changed rx tx connection in cable, tried all speeds, but still its not recognising the handset |
12-19-2006, 08:46 | #13 (permalink) | |
The only one thing can helps - please, double check cable again. | |
12-24-2006, 07:56 | #15 (permalink) |
Freak Poster Join Date: May 2006
Member: 275159 Status: Offline Thanks Meter: 7 | This is the correct pinnout for Spice S500 keyboard top 1.........18 1: Gnd 2: Gnd 13: Tx 14: Rx 18: Gnd Teste with 3 phones. No need to connect all Gnd pins ... 1 is enough ... Names are exactly as printed on Infinity Box ... The problem with the pinnout from Infinity Team ... Keyboard TOP is ... in fact UNDER ... so ... it works if you reverse everything :-) |
cu 500 unlocking problem coud not fide needed com pot | rohit50 | VygisToolbox | 6 | 04-03-2009 10:04 |
ke 500 unlock problem | whiteribbon | VygisToolbox | 1 | 03-07-2009 14:50 |
ke 500 unlock problem | dheeraj_b | VygisToolbox | 2 | 03-28-2008 05:36 |
S-500 Unlock Problem | Naresh | Infinity-Box | 4 | 12-11-2006 13:43 |
Z-500 unlock problem "USB Port Open Fail" | virtualone | QUALCOMM Models (3G) | 10 | 07-05-2005 02:35 |
