QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
07-01-2005, 16:42 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Age: 51
Member: 157361 Status: Offline Thanks Meter: 0 | Z-500 unlock problem "USB Port Open Fail" Followed the guide in another thread down here and d:led the QIWS V1.16 prog. Managed to fix the db9-connector and everything seemed to run fine while using the prog until it comes to "Searching SAMSUNG Modem..." Then I get "USB Port Open Fail" Say what? - I can use the EasyStudio w/o problems via the USB-port so why does this program fail???? Anyone got an answer? - I'd be most grateful!!! /Mats |
07-01-2005, 17:42 | #3 (permalink) | |
Member: 157361 Status: Offline Thanks Meter: 0 | Quote:
I have the modem drivers installed and I use a short circuited db9-connector (pin2-3) as well as the USB cable that was included with the phone! - I start the IMEI Writer program, select SGH-Z105U and [08]Sweden[Tla], then OK - and then I get to the screen that's seen on the attached image, then I press 'unlock' - and the result is what you see on the jpg :-( | |
07-01-2005, 18:20 | #4 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | then change the phone model,there are z105,z105u and z105t.I had also one that was making troubles like this and I short cutted min 2 & 3 with tweezers after 2 sec when I press unlock.And as I see your phone is z500 and not z105 or you made a mistake in writing? regards |
07-01-2005, 18:30 | #5 (permalink) |
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | If you are using original cable for data transfer also can not be done.Use this picture http://forum.gsmhosting.com/vbb/show...3&page=2&pp=15 for making cable for it if you haven't made like this. regards |
07-01-2005, 18:47 | #6 (permalink) | |
obviously be used for both phones as said in the thread "Samsung SGH-Z500 complete unlock solution" in this same forum, because it's from that link being mentioned in that thread that I've dl:ed the prog... | |
07-04-2005, 06:38 | #8 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Sweden Age: 51
Member: 38782 Status: Offline Thanks Meter: 9 | Quote:
You can choose what ever you want. if you only going to unlock the phone.. | |
07-04-2005, 21:15 | #9 (permalink) | |
07-04-2005, 21:30 | #10 (permalink) |
No Life Poster Join Date: Apr 2002
Member: 10964 Status: Offline Thanks Meter: 285 | in 'service PC' after some time you have too many modems installed. after i erased old modems from motorola, nec, nokia etc i unlocked wright away that z500. hope this help all lazy people who don't fell like pressing fe keys on keyboard |
ke 500 unlock problem | whiteribbon | VygisToolbox | 1 | 03-07-2009 14:50 |
ke 500 unlock problem | dheeraj_b | VygisToolbox | 2 | 03-28-2008 05:36 |
S-500 unlocking problem | parveen kumar | Infinity-Box | 31 | 03-01-2007 11:58 |
S-500 Unlock Problem | Naresh | Infinity-Box | 4 | 12-11-2006 13:43 |
Z130 unlock always USB port open fail | Singh05 | FuriouS II | 58 | 03-09-2006 22:51 |
