11-21-2015, 05:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 195 | Samsung copy-sm-g900f-6571 nand not support Log is here... Card found : S/N : CE1A9488 , v0129 Chinese Miracle II [MTK module] v 1.37 Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 002C00BC009000550056000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , [Micron] MT29C4G96MAZAPCJA_5IT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
