08-02-2008, 14:08 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | SE K200i Fixed with Infinity Damaged by Other Tool thanks for you powerfull tool i've unlocked one SE K200i with another tool but after unlock with sim it was restarting but without sim says insert sim card i try with another tool but still same then i use Infinity software at the last and woww my SE k200i is working fine again. here is the log. Code: ==== log opened: [2/8/2008 3:16:17 PM] ==== Application: C:\Program Files\InfinityBox\HModule\HModule.exe Loading data, wait... [Infinity Box] v1.21 S/N: 0000:0000 Wait... Current model: Sony-Ericsson-K200i Done Warning ! Settings will be cleared, user data erased ! Do you want to continue ? COM5 [VCP0] selected Device: Sony-Ericsson-K200i "advanced chip detection" active Action: reset Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb version sw: R1AC003 version sw: CXC1251062 version flex: CDA102773/56 imei: 3561******xx Check hardware done Read data... reading Sony-Ericsson-K200i_3561*********_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson-K200i_3561*********_eeprom_calibration-1_20080802-151701.80E.bin reading Sony-Ericsson-K200i_3561******xx_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson-K200i_3561*********_eeprom_calibration-2_20080802-151706.80E.bin reading Sony-Ericsson-K200i_3561******xx_ffs... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson-K200i_3561******xx_ffs_20080802-151853.80E.bin Read data done Check data... Check data done Writing... flash: 01227E22212200:46237300000000 Erase: ffs Writing done Finished, time used: 150 sec Remove/Install battery now ! Take Care ENJOY |
The Following User Says Thank You to imran_qasim For This Useful Post: |
08-02-2008, 16:17 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
W450 damaged by other box | nicacel | Rocker Dongle (By Legija) | 15 | 07-14-2009 07:34 |
F480 unlocked successfully with micro but rejected by other tools | sairat | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 07-10-2009 09:24 |
Alcatel S-320......can not flash? :: DAMAGED BY OTHER TOOL UNLOCKED BY POLAR :: | husainm | PolarBox 3 | 20 | 05-30-2009 02:53 |
SE K200i off with sim solved | zeerik | Infinity-Box | 0 | 04-23-2009 09:04 |
How to repair V360 damaged by other tool | Bi0H4z4rD | Smart-Clip | 3 | 08-11-2008 09:11 |
