10-12-2009, 12:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | sigmatel S7 dead here is formating log: COM3 [VCP1] selected module v2.93 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001603:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18001400000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18001400000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:18001400000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:18001400000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18001400000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18001400000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18C0140000009FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.N218B_R1_0_ 99_1.BIN ver. sw 2: N218B_R1.0.99.1, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:18001400000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.N218B_R1_0_ 99_1__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\PROWAVE25_GEMINI_ PCB01_GPRS_MT6225_S00.N218B_R1_0_99_1__ffs_2009101 2-161655.B0E.bin flash: 98004900000002:18001400000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98004900000002:18001400000000 Finalization Done Finished, time used: 142 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! i mostly faced this problem in most phones but failed to repair any phone. Great masters are requested to help to solve the problem. Quick reply will be appreciated. |
spice s7 dead by format | jitugrover | Infinity-Box | 21 | 12-23-2009 16:28 |
sigmatel s1 dead after flash | bhogpurmail | Infinity-Box | 18 | 09-22-2008 18:40 |
sigmatel s1 dead | jitugrover | Chinese Models & Cloned Phones | 2 | 08-08-2008 12:24 |
sigmatel s3 dead | ka jagan | Chinese Models & Cloned Phones | 7 | 07-28-2008 13:16 |
sigmatel auto dead | venusmobilecare | Chinese Models & Cloned Phones | 6 | 06-24-2008 12:35 |
