Old 04-14-2019, 14:59   #1 (permalink)
Member: 130995
Thanks Meter: 35,227
Smart-Card/Dongle/Box update problems and solutions
Dear Sirs,
If you have a problem with your Box/Dongle Smart-Card please copy/paste here text given by Infinity DongleManager software.
- Copy/paste ONLY TEXT but not pictures and/or video !
- Do not update your Smart-Card many times to avoid permanent Smart-Card damage !
- If you have Card-Reader Type FT SCR2000 you should use special Card-Reader Drivers - CardReader_Fetian_FT2K.7z
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - https://www.infinity-box.com/support/?r=6
- If you have DITS CCID Smart Card Reader you should use another Card-Reader because this Card-Reader may damage your Smart-Card permanently !
- For today best results gives Alcor Card-Readers.
Previous thread is here - http://forum.gsmhosting.com/vbb/f296...tions-2142000/
The Following 5 Users Say Thank You to InfinitySupport For This Useful Post:
Old 04-14-2019, 16:02   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
Just need to know Smartcard reader type
Good?
=== DongleManager [Infinity] v1.70 [4/14/2019 19:56:26] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 010267xx103212xx
Box/Dongle found: [BEST]
Serial No (S/N): xxxx
Firmware version: 0122.02
"UK Edition" status: Off
Last launched Application: 0030 v.0158
=> Activations:
- 00: Infinity-Box/Dongle v.0137
- 03: [BEST] v.0122
- 07: module #07
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post:
Old 04-14-2019, 18:31   #3 (permalink)
Member: 130995
Originally Posted by syed tuqeer View Post
Hello,
Good?
Searching...
=> Activations:
- 03: [BEST] v.0122
- 07: module #07
Hello,
I you have no problem with dongle firmware update this means reader is good.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 04-17-2019, 05:08   #4 (permalink)
Member: 889756
Thanks Meter: 10
hi
please help for My dongle Infinity Best nokia
Infinity-Box CardID v1.09
Error when connecting Card in: FT SCR2000 0
SmartCard API error #2148532329
The smart card has been removed, so that further communication is not possible.
The Following User Says Thank You to negintype For This Useful Post:
Old 04-17-2019, 07:42   #5 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by negintype View Post
hi
Hello,
Try to connect Dongle to another PC
Try to insert Smart-Card into another Card-Reader or Box (if you have it)
If problem still exist:
​- Remove Smart-Card from Card-Reader
- Clean Smart-Card contacts
- Try to use hot air gun and heat Smart-Card
- Insert Smart-Card back to Card-reader​
Old 04-17-2019, 16:01   #6 (permalink)
Member: 638580
Thanks Meter: 6
=== DongleManager [Infinity] v1.70 [17.04.2019 20:03:41] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0000D11E00001942
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 773DD11E
Firmware version: 0137.02
=== Process started: 17.04.2019 20:03:45 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Contact to http://www.infinity-box.com/support/?r=2
The Following User Says Thank You to alnext For This Useful Post:
Old 04-17-2019, 16:14   #7 (permalink)
Member: 1043909
Reading...
Hello,
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software.
What to do now:
- Delete fault.bin file from software folder (if you have it there)
- Install latest Infinity software updates
- Run DongleManager
- Update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
Old 04-18-2019, 13:40   #8 (permalink)
Member: 889756
Thanks Meter: 10
Old 04-19-2019, 12:45   #9 (permalink)
Member: 2360950
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 01039F5D1C6A1292
Reading...
Serial No (S/N): CF529F5D
=== Process started: 19.04.2019 16:43:53 ===
plese help me warning dongle misconfiguration
The Following User Says Thank You to adik_88 For This Useful Post:
Old 04-19-2019, 23:04   #10 (permalink)
Member: 1043909
Hello,
result ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 04-19-2019, 23:05   #11 (permalink)
Member: 1043909
Hello,
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software.
What to do now:
- Run DongleManager
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 04-20-2019, 04:57   #12 (permalink)
Member: 889756
Thanks Meter: 10
I did not get an answer
Old 04-20-2019, 04:57   #13 (permalink)
Member: 889756
Thanks Meter: 10
Originally Posted by YellowBoss View Post
Hello,
result ?
The Following 2 Users Say Thank You to negintype For This Useful Post:
Old 04-20-2019, 06:51   #14 (permalink)
Member: 1043909
Hm... You are replying to answer.
Ok, no problem, let me try once again:
If problem still exist this means it's a hardware problem and you should buy new Dongle.
Old 04-23-2019, 07:00   #15 (permalink)
Member: 1939490
Sonork: 100.1638723
Thanks Meter: 22
Renew for 2 year , Update Firmware error,
=== DongleManager [Infinity] v1.72 [23-04-2019 11:26:26] ===
Box/Dongle type selected: [BEST]
HWID: 0109777A24881292
=== Process started: 23-04-2019 11:26:26 ===
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Serial No : 9431777A
The Following 2 Users Say Thank You to ahsan.mt For This Useful Post:
Page generated in 0.33497 seconds with 9 queries
