08-17-2017, 09:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: manila ph. Age: 39
Member: 895644 Status: Offline Sonork: 098765 Thanks Meter: 161 | Smartcard dead help me Card found : S/N : 5FBD169F , v0135 THIS IS MAY DEAD SMARTCARD I WANT IT TO TRANSFER HER === DongleManager [Infinity] v1.70 [8/17/2017 16:49:06] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 000132D2FF021982 Box/Dongle is not found |
08-17-2017, 23:15 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box (if you have it) If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If problem still exist this means it's a hardware problem and you need new Smart-Card. |
08-18-2017, 15:20 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | please do not spam this forum with repeated posts. you must use one post and you must explain your problem well instead of write "Where is cm2 support". I can not understand the problem well. Please think and explain in details what do you want to do. |
08-20-2017, 04:12 | #8 (permalink) |
Member: 895644 Status: Offline Sonork: 098765 Thanks Meter: 161 | Sir your response is low and i am not spamming i want quick help may cm2 smartcard activated is dead pls backread may post i follow all the trikcs you post reply but smartcard not response anymore so i want may activation transfer in may 1 dongle can you help me to DO that cm2 team. S/n : 5fbd169f this is may smartcard serial key dead. |
08-20-2017, 11:42 | #9 (permalink) |
Member: 895644 Status: Offline Sonork: 098765 Thanks Meter: 161 | === DongleManager [Infinity] v1.70 [8/20/2017 18:37:38] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 000132D2FF021982 === Process started: 8/20/2017 18:37:38 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 THIS LOG ERROR IN OLD SMARTCARD THAT I INSERT IN CM2BOX |
08-21-2017, 08:41 | #11 (permalink) | |
Make one post with clear information instead of make many spam posts with useless information. Thank you ! | |
08-21-2017, 08:43 | #13 (permalink) | |
