Old 05-04-2016, 13:14   #1 (permalink)
shamshad quresh's Avatar
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
sprd3 J5500 (6531) connection problem
i try all bootkey but always connection problem. i also check with boot cable but same any body help thanks
Operation : Format File System / Reset Settings [ v1.16 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 21 ]
Port Opened
Sync...
Initial Boot Failed!
Reconnect Power/Cable!
Old 05-04-2016, 13:24   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Try this trick- first connect usb cable, press boot key (in case of boot cable no need to press boot key) and then click on required operation in software and insert battery.
Br.
Infinity Box Support Team.
Old 05-04-2016, 13:34   #3 (permalink)
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
also try this method but same
Old 05-04-2016, 14:11   #4 (permalink)
Member: 2551646
Thanks Meter: 41
Arrow
Boot key problem. If you fail then open the phone and connect TX and GND with coil and then work then you not need any boot key.
Old 05-04-2016, 14:37   #5 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 213
TX and GND with coil plz can u explain which coil on board
Old 05-04-2016, 16:07   #6 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 213
Operation : Read User Code [ v1.16 ]
3. Insert battery
Phone found! [ 20 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Check data... Can take some time
User Code : 0000
Done!
Elapsed: 00:00:21
thx...Try this trick- first connect usb cable, press boot key (in case of boot cable no need to press boot key) and then click on required operation in software and insert battery.
Old 05-05-2016, 06:56   #7 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
Remove Old drivers garbage (use dc-Uninstaller)
download / Install drivers from Support Site only
post result logs....
BTW
J5500 supported
http://forum.gsmhosting.com/vbb/11679047-post7154.html
Page generated in 0.18508 seconds with 8 queries
