01-20-2024, 06:37 | #75751 (permalink) |
No Life Poster Join Date: Jul 2010 Location: B.J.M Age: 36
Member: 1338323 Status: Offline Sonork: 100,1662431 Thanks Meter: 301 | Itel s661l sp9863a Frp 1 2 3 Done Infinity CM2SP3 v2.20 Code: Wait... S/N: 0020AA17E1 v0159 Chinese Miracle II - SP3 Service Tool v2.20 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... SP3 boot-pack 2024-01-11 Ok boot-pack is not installed or outdated Check for updates [CM2SP3]... You have latest version [2.20] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Ready Selected: itel A05s [Boot FireFly] Selected: itel vision-3 [Boot FireFly] Selected: itel vision-3 [Boot FireFly] Operation: Connect [Boot FireFly] [v2.20] Wait... - Power device Off - Connect cable [Connect test-point if need] Waiting for device... Device found PTFN: SPRD U2S Diag (COM37) vid: 0x1782 pid: 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? Loader exec Ok Dev UID: 05f9e4bcbf9c807a4091ea2e9c09caedcfcb8898ad0aa3b19c9cb5be70eef760 get storage info... EMMC cid: 15010051583633414203C6EABA64A829 crc Ok Vendor: Samsung OEM: 256 ID: 515836334142 [QX63AB] PRV: 0x03 Serial: 3337271908 0xC6EABA64 MM/YY: 10/2021 CSD: D02701320F5903FFF6DBFFEF8E404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 ERASE_GROUP_DEF: 0x 0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 SIZE: 0x00400000 4.00 Mb WP_GRP_SIZE: 0x00800000 8.00 Mb RPMB size: 0x00400000 4.00 Mb SIZE: Market 32 Gb SIZE: Actual 0x747C00000 29.12 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\sc9863_05f9e4bcbf9c807a_extcsd_0015-Samsung_QX63AB_5.1_2024-01-20.bin Verify config values... Ok get partitions... Partitions: 74 items Connected get slots... slot: a get sw info... probe boot... [vendor_boot_a] [boot_a] SW: Itel/F6318/itel-S661L:11/RP1A.201005.001/GL-V056-20220602:user/release-keys Product Brand: Itel Product Device: S661L Product Model: itel S661L Product Name: S661L Patch Level: RP1A.201005.001 Display ID: S661L-F6318-11.0-GL-V056-20220602 SW Version: GL-V056-20220602 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-05-05 Build Time: 6/2/2022 7:04:52 AM Product Name: F6318 Product Device: itel-S661L CPU: armeabi-v7a,armeabi Product Info: S661L SW: S661L-user 11 RP1A.201005.001 360 release-keys Product Board: S661L Board Platform: sp9863a Product Manfct: ITEL MOBILE LIMITED Android Ver: 11; UserDataFS: 0x02 [ext4|8+]; CacheFS: 0x02 [ext4|8+] Tag: itel-mobile-limited-itel-s661l-f6318 Strategy: [none|generic] Firmware ID: SP9863A_ITEL_MOBILE_LIMITED_itel_S661L_OSv11_S661L-F6318-11.0-GL-V056-20220602_RP1A.201005.001_S661L_Itel mdm info... N/A Read Device-ID... IMEI[0]: 351580731072043 IMEI[1]: 351580731072050 IMEI[2]: 867400020316638 IMEI[3]: 867400020316646 BT MAC: c0:fb:c1:7b:a2:ef WF MAC: c0:fb:c1:7b:a2:f0 Backup 8 items to: C:\InfinityBox\CM2SP3\backup\sc9863_05f9e4bcbf9c807a\ Read [1/8] prodnv 10.00 Mb Ok Read [2/8] miscdata 1024.00 Kb Ok Read [3/8] uboot_a 1024.00 Kb Ok Read [4/8] uboot_b 1024.00 Kb Ok Read [5/8] l_fixnv1_a 2.00 Mb Ok Read [6/8] l_fixnv2_a 2.00 Mb Ok Read [7/8] l_fixnv1_b 2.00 Mb Ok Read [8/8] l_fixnv2_b 2.00 Mb Ok Done 8 files Compress: C:\InfinityBox\CM2SP3\backup\sc9863_05f9e4bcbf9c807a\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sc9863_05f9e4bcbf9c807a.7z Verified [5e57ed18] Finished 1 min 35 sec Operation: Reset Settings / Format FS [Boot FireFly] [v2.20] WARNING: Reset may delete ALL USER DATA! Continue? No Operation: Reset Settings / Format FS [Boot FireFly] [v2.20] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [-] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sc9863_05f9e4bcbf9c807a Stage: FRP... Looking for items... 1 item(s) found [1] Writing... Ok Completed Finished 9 sec Reboot... Disconnect cable if it freez fault 0x05 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT Bye [0] |
The Following 2 Users Say Thank You to bidhan_mobile For This Useful Post: |
01-20-2024, 06:47 | #75752 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Samsung Galaxy A04e SM-A042F S5 FRP remove done original poster DZ-Djamel-GSM DZGSM |
The Following 4 Users Say Thank You to profkefah For This Useful Post: |
01-20-2024, 07:59 | #75753 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 46 | itel it2136 format done SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1B8 22A2979EF_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
01-20-2024, 08:06 | #75754 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | club mobile A1000 format done SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_048 DF2CD2539_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
01-20-2024, 11:41 | #75755 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | tecno bf7 frp remove done peration: Identify Device [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] High-Speed [+] Auto-EMI [+] FireFly-Over-DA extended protocol [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM9) MODE [0]: PRELOADER PORT; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 0EABEA70DD37361CAA9507254B4CE9BCF52120D7FC4797B145 D0FC24B9CA034B IRG: 0x00000080 AGENT: AUTO: Tecno: 2023-11 [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: F401224152563131581333BCA41DB9FF crc Ok Ven: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 SNN: 868000797 [0x33BCA41D] MM/YY: 11/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE90000000 [ 58.25 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 094885E59D88A5682E2800932B2D6CC5 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Get slot info... a Select info source... boot_a [2000000] Ok Product Brand: TECNO Product Device: TECNO-BF7 Product Model: TECNO BF7 Product Name: BF7-GL SW: TECNO/BF7-GL/TECNO-BF7:12/SP1A.210812.016/230719V1237:user/release-keys Patch Level: SP1A.210812.016 Display ID: BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230719V1237 SW Version: 230719V1237 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-06-05 Build Time: 7/18/2023 10:08:06 PM Product Info: bf7_h6127 SW: vnd_bf7_h6127-user 12 SP1A.210812.016 382656 release-keys Product Manfct: TECNO Product Board: TECNO-BF7 Board Platform: mt6761 Strategy: [none|generic] Firmware ID: MT6761_TECNO_TECNO_BF7_OSv12_BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230719V1237_SP1A.210812.016_bf7_h6127 Verify firmware [MT6761_TECNO_TECNO_BF7_OSv12_BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230719V1237_SP1A.210812.016_bf7_h6127]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA3 Size: 0x08C41F State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 1CAB483ACEA0 IMEI[1]: 358943515047263 IMEI[2]: 358943515047271 Verify config values... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6761__F798EE6B93D5E 625DEC3CB43215091EC\ Items to check: 22 Read [16] NVRAM Read [8] NVDATA Read [3] PROINFO Read [7] NVCFG Read [11] PROTECT1 Read [1] PGPT Read [14] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6761__F798EE6B93D5E 625DEC3CB43215091EC\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__F798EE6B93D5E 625DEC3CB43215091EC.7z Verified STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6761 preloader_bf7_h6127.bin with 6 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_b f7_h6127.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_b f7_h6127.bin [7e187d03]... Exist Probe FRP... On Probe MDM... Request... Ok Nothing found Probe network config... State: Default Reset port... Trying to reboot... Done: 00:00:48 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM9) MODE [0]: PRELOADER PORT; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 0EABEA70DD37361CAA9507254B4CE9BCF52120D7FC4797B145 D0FC24B9CA034B IRG: 0x00000080 AGENT: AUTO: Tecno: 2023-11 [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: F401224152563131581333BCA41DB9FF crc Ok Ven: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 SNN: 868000797 [0x33BCA41D] MM/YY: 11/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE90000000 [ 58.25 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 094885E59D88A5682E2800932B2D6CC5 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Get slot info... a Select info source... boot_a [2000000] Ok Product Brand: TECNO Product Device: TECNO-BF7 Product Model: TECNO BF7 Product Name: BF7-GL SW: TECNO/BF7-GL/TECNO-BF7:12/SP1A.210812.016/230719V1237:user/release-keys Patch Level: SP1A.210812.016 Display ID: BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230719V1237 SW Version: 230719V1237 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-06-05 Build Time: 7/18/2023 10:08:06 PM Product Info: bf7_h6127 SW: vnd_bf7_h6127-user 12 SP1A.210812.016 382656 release-keys Product Manfct: TECNO Product Board: TECNO-BF7 Board Platform: mt6761 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__F798EE6B93D5E 625DEC3CB43215091EC Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:26 Reconnect Power/Cable now |
01-20-2024, 11:49 | #75756 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | vivo y30 remove pattern & frp done Operation: Identify Device [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] High-Speed [+] Auto-EMI [+] FireFly-Over-DA extended protocol [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM9) MODE [0]: PRELOADER PORT; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 6A73A1C99B544EF8F1F6203E5CD4CE73ECDC97047B25903B5F 5A5746A3CECED6 AGENT: AUTO: Vivo: 2023-08 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.bin Looking for suitable BootChain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395238100695C42B57E5 crc Ok Ven: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 SNN: 110478379 [0x0695C42B] MM/YY: 5/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 9B65156794794BF4CDBD299D5EE1157E USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 46 Select info source... recovery [6000000] Ok SW: vivo/1938N/1938:10/QP1A.190711.020/compiler08241240:user/release-keys Product Brand: vivo Product Device: k65v1_64_bsp Product Model: vivo 1938N Product Name: full_k65v1_64_bsp Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys SW Version: compiler08241240 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-06-01 Build Time: 8/24/2022 5:20:21 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 10 QP1A.190711.020 compiler08241240 release-keys Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Strategy: [none|generic] Firmware ID: MT6765_vivo_vivo_1938N_OSv10_QP1A.190711.020_k65v1 _64_bsp Verify firmware [MT6765_vivo_vivo_1938N_OSv10_QP1A.190711.020_k65v1 _64_bsp]... Exist (1) Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Analyze modem... BBK_Q0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY _LR12A_R2_MP_V102_7_P88 Analyze nvram... NVRAM: Items: 0xB7 Size: 0x125127 State: Ok WiFi MAC: 708F47E306F3 BlTh MAC: 708F47E306F2 IMEI[1]: 865865049426612 IMEI[2]: 865865049426604 Verify config values... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__381D66373B483 E1B77DE4E19F61B211F\ Items to check: 22 Read [34] NVRAM Read [10] NVDATA Read [24] PROINFO Read [35] LK Read [9] NVCFG Read [19] PROTECT1 Read [1] PGPT Read [22] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__381D66373B483 E1B77DE4E19F61B211F\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__381D66373B483 E1B77DE4E19F61B211F.7z Verified STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_k65v1_64_bsp.bin with 9 memory type(s) 1. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395038 Micron G1J9P8 RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin [b7b7b90c]... Exist Probe FRP... On Probe MDM... Request... Ok Nothing found Probe network config... State: Default Reset port... Trying to reboot... Done: 00:01:07 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [+] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM9) MODE [0]: PRELOADER PORT; PORT: 9 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 6A73A1C99B544EF8F1F6203E5CD4CE73ECDC97047B25903B5F 5A5746A3CECED6 AGENT: AUTO: Vivo: 2023-08 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\2023-08\MTK_AllInOne_DA_v3.bin Looking for suitable BootChain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395238100695C42B57E5 crc Ok Ven: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 SNN: 110478379 [0x0695C42B] MM/YY: 5/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 9B65156794794BF4CDBD299D5EE1157E USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 46 Select info source... recovery [6000000] Ok SW: vivo/1938N/1938:10/QP1A.190711.020/compiler08241240:user/release-keys Product Brand: vivo Product Device: k65v1_64_bsp Product Model: vivo 1938N Product Name: full_k65v1_64_bsp Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys SW Version: compiler08241240 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-06-01 Build Time: 8/24/2022 5:20:21 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 10 QP1A.190711.020 compiler08241240 release-keys Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Strategy: [none|generic] SmartInfo: Android Ver: 10 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__381D66373B483 E1B77DE4E19F61B211F Stage: Android OS [2] WIPE... Skip [3] WIPE... Create image... Ok Ok [4] WIPE... Create image... Ok Ok [6] USERDATA... Ok Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:45 Reconnect Power/Cable now |
01-20-2024, 13:45 | #75757 (permalink) |
No Life Poster Join Date: Mar 2008 Location: In My Shop, Bangladesh
Member: 733449 Status: Offline Sonork: 100.334100 Thanks Meter: 292 | Tecno Camon 20 Pro CK7N Restart on logo Done by flashing Operation: Write Flash [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Re-Partition [-] Checksum Verify [+] Pre-Erase [+] Check compatibility [+] Backup [-] FLASH ERASE C:\Users\Somrat Telecom\Desktop\CK7n-H894ABC-T-GL-230419V947(MobiFirmware.com)\CK7n-H894ABC-T-GL-230419V947(MobiFirmware.com)\ preloader_ck7n_h894.bin [ 348.32 Kb ] 3d1fbf9a preloader_ck7n_h894.bin [ 348.32 Kb ] 3d1fbf9a tkv.img [ 1.00 Mb ] 57566ced vbmeta.img [ 8.00 Kb ] bfd11f37 vbmeta_system.img [ 4.00 Kb ] dd1ab4dc vbmeta_vendor.img [ 4.00 Kb ] e3e9b147 md1img.img [ 51.03 Mb ] spmfw.img [ 14.34 Kb ] 3429478e pi_img.img [ 15.97 Kb ] 10696dbc dpm.img [ 144.70 Kb ] f1a53a14 scp.img [ 425.67 Kb ] 785b14e7 sspm.img [ 703.88 Kb ] bda5c894 mcupm.img [ 124.91 Kb ] 7e07a297 gz.img [ 2.57 Mb ] d39281ef lk.img [ 2.18 Mb ] 7b7926b2 logo.bin [ 594.11 Kb ] 4e068f9e boot.img [ 64.00 Mb ] vendor_boot.img [ 64.00 Mb ] dtbo.img [ 8.00 Mb ] b8c78e59 tee.img [ 750.67 Kb ] 264ef190 efuse.img [ 512 B ] e4b6e24e logo.bin [ 594.11 Kb ] 4e068f9e super.img [ 6.11 Gb ] tranfs.img [ 100.14 Kb ] b6f5678b userdata.img [ 14.70 Mb ] Files: 25; Total size: 0x1945F3720 [ 6.32 Gb ] Product Brand: TECNO Product Device: TECNO-CK7n Product Model: TECNO CK7n Product Name: CK7n-GL SW: TECNO/CK7n-GL/TECNO-CK7n:12/SP1A.210812.016/230419V861:user/release-keys Patch Level: SP1A.210812.016 Display ID: CK7n-H894ABC-T-GL-230419V861 SW Version: 230419V861 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-04-05 Build Time: 19/04/2023 11:06:16 Product Info: ck7n_h894 SW: vext_ck7n_h894-user 12 SP1A.210812.016 305491 release-keys Product Manfct: TECNO Product Board: TECNO-CK7n Board Platform: mt6789 Firmware ID: MT6789_TECNO_TECNO_CK7n_OSv12_CK7n-H894ABC-T-GL-230419V861_SP1A.210812.016_ck7n_h894 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6789 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1208 CODE: G99 TYPE: NEXTGEN [LUCI] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 670DA5D6DACCDEC93E59794AD1F36A85F79B22366EB964143E 29AAFB99A23CA2 AGENT: MANUAL: Tecno: 2023-11 [b03eefaf] C:\Users\Somrat Telecom\Desktop\TECNO CK7n MDM Remove (Just Flashing) CK7n-H894B-T-RU-230720V1442\MDM\download_agent\DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth [3d1fbf9a] C:\Users\Somrat Telecom\Desktop\CK7n-H894ABC-T-GL-230419V947(MobiFirmware.com)\CK7n-H894ABC-T-GL-230419V947(MobiFirmware.com)\preloader_ck7n_h894.b in Looking for suitable BootChain in DA... Found: MT6789; DA: MTK_DOWNLOAD_AGENT ID6 vendor: 5 BROM: Sending 1st DA... Reset Interface PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM5) MODE [0]: PRELOADER PORT; PORT: 5 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6789 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1208 CODE: G99 TYPE: NEXTGEN [LUCI] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 670DA5D6DACCDEC93E59794AD1F36A85F79B22366EB964143E 29AAFB99A23CA2 AGENT: MANUAL: Tecno: 2023-11 [b03eefaf] C:\Users\Somrat Telecom\Desktop\TECNO CK7n MDM Remove (Just Flashing) CK7n-H894B-T-RU-230720V1442\MDM\download_agent\DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth [3d1fbf9a] C:\Users\Somrat Telecom\Desktop\CK7n-H894ABC-T-GL-230419V947(MobiFirmware.com)\CK7n-H894ABC-T-GL-230419V947(MobiFirmware.com)\preloader_ck7n_h894.b in Looking for suitable BootChain in DA... Found: MT6789; DA: MTK_DOWNLOAD_AGENT ID6 vendor: 5 BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Agent Started LC: Agent online Agent ENV tuned succesfully Version: 1.2 DevRND: FF084737D59D71F775C89E9728D26CD5 Battery: 3601 mV RAM Size: 0x0000000000 [ 0 B ] Storage: UFS ID: eUFS2.2_256 BLK: 0x00001000 LUN0: 0x0000400000 [ 4.00 Mb ] LUN1: 0x0000400000 [ 4.00 Mb ] LUN2: 0x3BAD800000 [ 238.71 Gb ] LUN3: 0x0000000000 [ 0 B ] LC: Hardware not initialized yet. Process HWinit... LC: Hardware init Ok LC: Set HostCapps... Ok LC: Set HostInfo... Ok Version: 1.2 DevRND: FF084737D59D71F775C89E9728D26CD5 Battery: 3609 mV RAM Size: 0x0200000000 [ 8.00 Gb ] Storage: UFS ID: eUFS2.2_256 BLK: 0x00001000 LUN0: 0x0000400000 [ 4.00 Mb ] LUN1: 0x0000400000 [ 4.00 Mb ] LUN2: 0x3BAD800000 [ 238.71 Gb ] LUN3: 0x0000000000 [ 0 B ] LC: Boot to 2nd Agent.. Ok LC2: Process HW init... Ok LC2: SLA request by agent, vendor: 5 SLA ID: 670DA5D6DACCDEC93E59794AD1F36A85F79B22366EB964143E 29AAFB99A23CA2 Request... Finished Received: 0x200 LC2: SLA: Challenge Pass CHIP: MT6789 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1208 CODE: G99 TYPE: NEXTGEN [LUCI] MEID: 670DA5D6DACCDEC93E59794AD1F36A85 USB: HIGH-SPEED Boot done NEXTGEN [LUCI] [FL]: COMBO scatter! Update settings to UFS [FL]: Set: preloader_ck7n_h894.bin [FL]: Set: preloader_ck7n_h894.bin [FL]: Set: tkv.img [FL]: Set: vbmeta.img [FL]: Set: vbmeta_system.img [FL]: Set: vbmeta_vendor.img [FL]: Set: md1img.img [FL]: Set: spmfw.img [FL]: Set: pi_img.img [FL]: Set: dpm.img [FL]: Set: scp.img [FL]: Set: sspm.img [FL]: Set: mcupm.img [FL]: Set: gz.img [FL]: Set: lk.img [FL]: Set: logo.bin [FL]: Set: boot.img [FL]: Set: vendor_boot.img [FL]: Set: dtbo.img [FL]: Set: tee.img [FL]: Set: efuse.img [FL]: Set: logo.bin [FL]: Set: super.img [FL]: Set: tranfs.img [FL]: Set: userdata.img HW verification... Ok Analyze PMT... PMT: PGPT [0x64] Records: 66 Verify config values... Ok Loaders Ok Pre-Flash backup... Backup exist: C:\InfinityBox\CM2MT2\backup\MT6789__670DA5D6DACCD EC93E59794AD1F36A85 Verify PMT... Scat|PMT: number of partitions mismatch Warning: DEVICE <-> FIRMWARE PartTable mismatch! Continue may destroy device security! Continue? Yes Ok Verify SEC DL... Pre-Erase... Erase: 0x0000000000000000 0x0000000000108000 Erase: 0x0000000000408000 0x0000000008200000 Erase: 0x000000000A608000 0x0000000009200000 Erase: 0x0000000018000000 0x000000001CA00000 Erase: 0x0000000035200000 0x0000000000F80000 Erase: 0x000000003A180000 0x0000000271680000 RePartition... Ok Analyze PMT... PMT: PGPT [0x64] Records: 66 Flash write... Write: PRELOADER [ 348.32 Kb ] Ok Write: PRELOADER_BACKUP [ 348.32 Kb ] Ok Write: TKV_A [ 1.00 Mb ] Ok Write: VBMETA_A [ 8.00 Kb ] Ok Write: VBMETA_SYSTEM_A [ 4.00 Kb ] Ok Write: VBMETA_VENDOR_A [ 4.00 Kb ] Ok Write: MD1IMG_A [ 51.03 Mb ] Ok Write: SPMFW_A [ 14.34 Kb ] Ok Write: PI_IMG_A [ 15.97 Kb ] Ok Write: DPM_A [ 144.70 Kb ] Ok Write: SCP_A [ 425.67 Kb ] Ok Write: SSPM_A [ 703.88 Kb ] Ok Write: MCUPM_A [ 124.91 Kb ] Ok Write: GZ_A [ 2.57 Mb ] Ok Write: LK_A [ 2.18 Mb ] Ok Write: LOGO_A [ 594.11 Kb ] Ok Write: BOOT_A [ 64.00 Mb ] Ok Write: VENDOR_BOOT_A [ 64.00 Mb ] Ok Write: DTBO_A [ 8.00 Mb ] Ok Write: TEE_A [ 750.67 Kb ] Ok Write: EFUSE [ 512 B ] Ok Write: LOGO_B [ 594.11 Kb ] Ok Write: SUPER [ 6.11 Gb ] Ok Write: TRANFS [ 100.14 Kb ] Ok Write: USERDATA [ 14.70 Mb ] Ok RePartition... Ok Trying to reboot... Done: 00:09:02 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to somratjisan For This Useful Post: |
01-20-2024, 13:45 | #75758 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-KG5j Frp Code: SW: TECNO/KG5j-OP/TECNO-KG5j:11/RP1A.200720.011/231010V472:user/release-keys Product Brand: TECNO Product Device: TECNO-KG5j Product Model: TECNO KG5j Product Name: KG5j-OP Patch Level: RP1A.200720.011 Display ID: KG5j-H6126ABC-RGo-OP-231010V472 SW Version: 231010V472 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-09-05 Build Time: 10/10/2023 2:50:20 am CPU: armeabi-v7a,armeabi Product Info: kg5j_h6126 SW: vnd_kg5j_h6126-user 11 RP1A.200720.011 449177 release-keys Product Board: TECNO-KG5j Board Platform: mt6761 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Firmware ID: MT6761_TECNO_MOBILE_LIMITED_TECNO_KG5j_OSv11_KG5j-H6126ABC-RGo-OP-231010V472_RP1A.200720.011_kg5j_h6126 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA2 Size: 0x08C12D State: Ok WiFi MAC: 8077A4DB4D1B BlTh MAC: 8077A4DB4D1A IMEI[1]: IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6761 preloader_kg5j_h6126.bin with 6 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_kg5j_h6126.bin Reset port... Done: 00:01:08 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.51 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM24) MODE [0]: PRELOADER PORT; PORT: 24 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 83ED13C26FCD958D55B9D73D3E140EE31383D9AC24BEA87F32FDC2B14F845F01 IRG: 0x00000080 AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 15010043555441343205CD198D4E58A3 EMMC crc Ok Ven: Samsung OEM: 256 ID: 435554413432 [CUTA42] PRV: 0x05 SNN: 3441003854 [0xCD198D4E] MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 3C380DBCA36EF5445A652BB36D8D5F57 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Strategy: [none|generic] Stage: Android OS [1] PROTECTION... Ok Stage: FRP... FRP is Off Reset port... Trying to reboot... Done: 00:00:27 Reconnect Power/Cable now |
01-20-2024, 16:40 | #75759 (permalink) |
Freak Poster Join Date: Mar 2011 Location: EGYPT Age: 37
Member: 1544111 Status: Online Sonork: 100.1611711 Thanks Meter: 80 | TA-1408 format+frp by cm2sp3 TA-1408 format+frp by cm2sp3 Operation: Connect [Boot FireFly] [v2.20b3 (beta)] Wait... - Power device Off - Connect test-point if need - Connect cable Waiting for device... Device found PTFN: SPRD U2S Diag (COM141) vid: 0x1782 pid: 0x4D00 crc? boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? Loader exec Ok Dev UID: 755e92f53472b88fe2a3a16c5fb10580ae599ec430126509f3 8450dbd5a3f77b get storage info... EMMC cid: D6010341334135363211F428A422C869 crc Ok Vendor: Foresee OEM: 259 ID: 413341353632 [A3A562] PRV: 0x11 Serial: 4096304162 0xF428A422 MM/YY: 12/2021 CSD: D0FFFF329F5903FFFFFFFFEF964000FF temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 ERASE_GROUP_DEF: 0x 0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 SIZE: 0x00400000 4.00 Mb WP_GRP_SIZE: 0x00800000 8.00 Mb RPMB size: 0x01000000 16.00 Mb SIZE: Market 128 Gb SIZE: Actual 0x1CCF000000 115.23 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: Not defined read extcsd... Ok extcsd backup exist, skip: C:\Users\MElmi\Desktop\New folder\backup\ext_csd\sc9230_755e92f53472b88f_extc sd_00D6-Foresee_A3A562_5.12024-01-20.bin Verify config values... Ok get partitions... Partitions: 69 items 0x00100000 0x00A00000 prodnv 0x00B00000 0x00500000 elabel 0x01000000 0x00100000 miscdata 0x01100000 0x00100000 misc 0x01200000 0x00600000 trustos_a 0x01800000 0x00600000 trustos_b 0x01E00000 0x00100000 sml_a 0x01F00000 0x00100000 sml_b 0x02000000 0x00800000 protect_data 0x02800000 0x00300000 uboot_a 0x02B00000 0x00300000 uboot_b 0x02E00000 0x00400000 uboot_log 0x03200000 0x00800000 logo_a 0x03A00000 0x00800000 logo_b 0x04200000 0x00800000 fbootlogo 0x04A00000 0x00200000 l_fixnv1_a 0x04C00000 0x00200000 l_fixnv2_a 0x04E00000 0x00200000 l_fixnv1_b 0x05000000 0x00200000 l_fixnv2_b 0x05200000 0x00200000 l_runtimenv1 0x05400000 0x00200000 l_runtimenv2 0x05600000 0x00100000 gnssmodem_a 0x05700000 0x00100000 gnssmodem_b 0x05800000 0x00A00000 wcnmodem_a 0x06200000 0x00A00000 wcnmodem_b 0x06C00000 0x00200000 persist 0x06E00000 0x01900000 l_modem_a 0x08700000 0x01900000 l_modem_b 0x0A000000 0x00100000 l_deltanv_a 0x0A100000 0x00100000 l_deltanv_b 0x0A200000 0x00A00000 l_gdsp_a 0x0AC00000 0x00A00000 l_gdsp_b 0x0B600000 0x01400000 l_ldsp_a 0x0CA00000 0x01400000 l_ldsp_b 0x0DE00000 0x00600000 l_agdsp_a 0x0E400000 0x00600000 l_agdsp_b 0x0EA00000 0x00100000 pm_sys_a 0x0EB00000 0x00100000 pm_sys_b 0x0EC00000 0x00100000 teecfg_a 0x0ED00000 0x00100000 teecfg_b 0x0EE00000 0x04000000 boot_a 0x12E00000 0x04000000 boot_b 0x16E00000 0x06400000 vendor_boot_a 0x1D200000 0x06400000 vendor_boot_b 0x23600000 0x00800000 dtb_a 0x23E00000 0x00800000 dtb_b 0x24600000 0x00800000 dtbo_a 0x24E00000 0x00800000 dtbo_b 0x25600000 0x1B5800000 super 0x1DAE00000 0x06400000 cache 0x1E1200000 0x04B00000 socko_a 0x1E5D00000 0x04B00000 socko_b 0x1EA800000 0x01900000 odmko_a 0x1EC100000 0x01900000 odmko_b 0x1EDA00000 0x00100000 vbmeta_a 0x1EDB00000 0x00100000 vbmeta_b 0x1EDC00000 0x01000000 metadata 0x1EEC00000 0x00A00000 sysdumpdb 0x1EF600000 0x00100000 vbmeta_system_a 0x1EF700000 0x00100000 vbmeta_system_b 0x1EF800000 0x00100000 vbmeta_vendor_a 0x1EF900000 0x00100000 vbmeta_vendor_b 0x1EFA00000 0x00100000 vbmeta_odm_a 0x1EFB00000 0x00100000 vbmeta_odm_b 0x1EFC00000 0x00100000 vbmeta_system_ext_a 0x1EFD00000 0x00100000 vbmeta_system_ext_b 0x1EFE00000 0x00100000 vbmeta_product_a 0x1EFF00000 0x00100000 vbmeta_product_b 0x1F0000000 0x1ADEE00000 userdata Connected get slots... slot: a get sw info... probe boot... [vendor_boot_a] [boot_a] SW: Nokia/ShadowcatPlus_00WW/SCP_sprout:11/RP1A.201005.001/00WW_1_21C:user/release-keys Product Brand: Nokia Product Device: SCP_sprout Product Model: Nokia G21 Product Name: ShadowcatPlus_00WW Patch Level: RP1A.201005.001 Display ID: 00WW_1_210_SP01 SW Version: 25429 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-06-01 Build Time: 6/23/2022 4:57:29 AM Product Model: 00WW Product Info: ShadowcatPlus_00WW SW Version: 00WW_1_21C CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: SCP_sprout SW: ShadowcatPlus_Natv-user 11 RP1A.201005.001 25429 release-keys Product Board: ShadowcatPlus Board Platform: ums9230 Product Manfct: HMD Global Android Ver: 11; UserDataFS: 0x02 [ext4|8+]; CacheFS: 0x02 [ext4|8+] Tag: hmd-global-nokia-g21-scp-sprout-shadowcatplus-00ww Strategy: [nokia] Firmware ID: UMS9230_HMD_Global_00WW_OSv11_00WW_1_210_SP01_RP1A .201005.001_SCP_sprout_Nokia Read Device-ID... IMEI[0]: 350073852237943 IMEI[1]: 350073852237950 IMEI[2]: 867400020316638 IMEI[3]: 867400020316646 BT MAC: 4c:d3:af:2b:92:c6 WF MAC: 4c:d3:af:2b:92:c5 Backup 10 items to: C:\Users\MElmi\Desktop\New folder\backup\sc9230_755e92f53472b88f\ Read [1/10] prodnv 10.00 Mb Ok Read [2/10] miscdata 1024.00 Kb Ok Read [3/10] uboot_a 3.00 Mb Ok Read [4/10] uboot_b 3.00 Mb Ok Read [5/10] l_fixnv1_a 2.00 Mb Ok Read [6/10] l_fixnv2_a 2.00 Mb Ok Read [7/10] l_fixnv1_b 2.00 Mb Ok Read [8/10] l_fixnv2_b 2.00 Mb Ok Read [9/10] wcnmodem_a 10.00 Mb Ok Read [10/10] wcnmodem_b 10.00 Mb Ok Done 10 files Compress: C:\Users\MElmi\Desktop\New folder\backup\sc9230_755e92f53472b88f\ Cleanup... Ok Verify C:\Users\MElmi\Desktop\New folder\backup\sc9230_755e92f53472b88f.7z Verified [1073d663] Finished 02:08 min Operation: Reset Settings / Format FS [Boot FireFly] [v2.20b3 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\Users\MElmi\Desktop\New folder\backup\sc9230_755e92f53472b88f Stage: FRP... Looking for items... 1 item(s) found [1] Writing... Ok Completed Stage: Userdata... [1] Format... [2] Format... [3] Format... Completed Stage: Smart... [20] Format... Ok [21] Format... Ok Completed Finished 00:34 min |
The Following 2 Users Say Thank You to melmitador For This Useful Post: |
01-21-2024, 10:34 | #75760 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO KF8 Frp Code: SW: TECNO/KF8-GL/TECNO-KF8:11/RP1A.200720.011/230324V1355:user/release-keys Product Brand: TECNO Product Device: TECNO-KF8 Product Model: TECNO KF8 Product Name: KF8-GL Patch Level: RP1A.200720.011 Display ID: KF8-H696ABFAlAm-R-GL-230324V1355 SW Version: 230324V1355 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-03-05 Build Time: 24/03/2023 10:21:31 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: kf8_h696 SW: vnd_kf8_h696-user 11 RP1A.200720.011 282773 release-keys Product Board: TECNO-KF8 Board Platform: mt6768 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Firmware ID: MT6768_TECNO_MOBILE_LIMITED_TECNO_KF8_OSv11_KF8-H696ABFAlAm-R-GL-230324V1355_RP1A.200720.011_kf8_h696 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xB8 Size: 0x122373 State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 58356BF66F28 IMEI[1]: IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6752 preloader_kf8_h696.bin with 15 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 150100335636434142 Samsung 3V6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 150100335036434D42 Samsung 3P6CMB RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_kf8_h696.bin Reset port... Done: 00:02:01 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.51 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM3) MODE [0]: BOOTROM; PORT: 3 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: E66FDBAF5B8F9543E959D9B28CAFC168 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: A4C7E4D53974BAC16F0D8CE35761474FB5F6BC2EEEAA5B3763ED570BA720EC06 SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: E66FDBAF5B8F9543E959D9B28CAFC168 AGENT: AUTO: 0_base: base_v2316 [1d5fdec4] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable BootChain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 1501004450364441420218E7CAA3589D EMMC crc Ok Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 417843875 [0x18E7CAA3] MM/YY: 5/2021 EMI: Init Ok EMI: FireFly preloader_kf8_h696.bin with 15 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Samsung DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445036444142 Samsung DP6DAB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 150100335636434142 Samsung 3V6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 150100335036434D42 Samsung 3P6CMB RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 150100445036444242 Samsung DP6DBB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445636444242 Samsung DV6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501004450364441420218E7CAA3589D EMMC crc Ok Ven: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 417843875 [0x18E7CAA3] MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: CE02E5BCBC8FE2C047E52BD8E74E2234 MEID: E66FDBAF5B8F9543E959D9B28CAFC168 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 51 Strategy: [none|generic] Stage: Android OS [1] PROTECTION... Ok Stage: FRP... FRP is Off Reset port... Trying to reboot... Done: 00:00:16 Reconnect Power/Cable now |
01-21-2024, 11:49 | #75761 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Realme RMX3830 Frp Code: Chinese Miracle II - SP3 Service Tool v2.20 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... SP3 boot-pack 2024-01-11 Ok Ready Selected: T612 [Boot FireFly] Operation: Connect [Boot FireFly] [v2.20] Wait... - Power device Off - Connect cable [Connect test-point if need] Waiting for device... Device found PTFN: SPRD U2S Diag (COM161) vid: 0x1782 pid: 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? Loader exec Ok Dev UID: 94e04cfd33f2dce54cc4fa197598e13b877564718574e288204eafff5d6bad07 get storage info... EMMC cid: 9B010059325030363400F161036F8A3B crc Ok Vendor: Hynix OEM: 256 ID: 593250303634 [Y2P064] PRV: 0x00 Serial: 4049666927 0xF161036F MM/YY: 8/2023 CSD: D04F01328F5903FFFFFFFFEF8A400001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 ERASE_GROUP_DEF: 0x 0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 SIZE: 0x00400000 4.00 Mb WP_GRP_SIZE: 0x00800000 8.00 Mb RPMB size: 0x01000000 16.00 Mb SIZE: Market 64 Gb SIZE: Actual 0xE8F800000 58.24 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\sc9230_94e04cfd33f2dce5_extcsd_009B-Hynix_Y2P064_5.1_2024-01-21.bin Verify config values... Ok get partitions... Partitions: 77 items Connected get slots... slot: a get sw info... probe boot... [vendor_boot_a] Product Brand: realme Product Device: RE58BC Product Model: ums9230_hulk_Natv Product Name: RMX3830 SW OTA Version: RMX3830export_13.A.33_0330_202312010039 SW: realme/RMX3830/RE58BC:13/TP1A.220624.014/T.R4T2.1701362372:user/release-keys Patch Level: TP1A.220624.014 Display ID: RMX3830export_13_A.33 SW Version: 608 Ver. CodeName: REL Ver. Release: 13 Sec. Patch: 2023-11-05 Build Time: 30/11/2023 5:26:35 pm Product Info: ums9230_hulk SW: ums9230_hulk_Natv-user 13 TP1A.220624.014 608 release-keys Product Manfct: realme Board Platform: ums9230 Product Board: ums9230_hulk Android Ver: 13; UserDataFS: 0x03 [f2fs]; CacheFS: 0x03 [f2fs] Tag: realme-ums9230-hulk-natv-re58bc-rmx3830 Strategy: [none|generic] Firmware ID: UMS9230_realme_ums9230_hulk_Natv_OSv13_RMX3830export_13_A.33_TP1A.220624.014_ums9230_hulk mdm info... N/A Read Device-ID... IMEI[0]: IMEI[1]: IMEI[2]: IMEI[3]: BT MAC: fc:2a:46:e8:e6:84 WF MAC: fc:2a:46:e8:e6:85 Backup 10 items to: C:\InfinityBox\CM2SP3\backup\sc9230_94e04cfd33f2dce5\ Read [1/10] prodnv 64.00 Mb Ok Read [2/10] miscdata 1024.00 Kb Ok Read [3/10] uboot_a 3.00 Mb Ok Read [4/10] uboot_b 3.00 Mb Ok Read [5/10] l_fixnv1_a 2.00 Mb Ok Read [6/10] l_fixnv2_a 2.00 Mb Ok Read [7/10] l_fixnv1_b 2.00 Mb Ok Read [8/10] l_fixnv2_b 2.00 Mb Ok Read [9/10] ocdt_a 8.00 Mb Ok Read [10/10] ocdt_b 8.00 Mb Ok Done 10 files Compress: C:\InfinityBox\CM2SP3\backup\sc9230_94e04cfd33f2dce5\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sc9230_94e04cfd33f2dce5.7z Verified [973a855c] Finished 3 min 47 sec Operation: Reset Settings / Format FS [Boot FireFly] [v2.20] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [-] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sc9230_94e04cfd33f2dce5 Stage: FRP... Looking for items... 1 item(s) found [1] Writing... Ok Completed Finished 4 sec |
01-21-2024, 16:10 | #75762 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | For Tecno Pop 5 LTE BD4a FRP remove done Code: Wait... S/N: 0041DEDF35 v0159 Chinese Miracle II - MT2 Service Tool v2.52 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 32 dirs: 3 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 82 DA profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok Check for updates [boot-pack]... You have latest version [2.43] installed Check for updates [CM2MT2]... You have latest version [2.52] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Update configuration... Configuration [12412] updated Load IDBase v915508 Ok DA selected: Tecno | 2023-05 | MTK_AllInOne_DA.bin | auth_sv5.auth Preloader Mode without test-point/disassembly. MT6739, MT6761, MT6763, MT6765, MT6768, MT6781, MT6785, MT6833, MT6877, MT6893 Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM43) MODE [0]: PRELOADER PORT; PORT: 43 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: DDA81582FD1C13B43F24FE38205468FF2F76680EFD7642DAED176F8B2F890FF8 IRG: 0x00000080 AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 700100544A333033320107271A364943 crc Ok Ven: Kingston OEM: 256 ID: 544A33303332 [TJ3032] PRV: 0x01 SNN: 120003126 [0x07271A36] MM/YY: 4/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x748000000 [ 29.13 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 6FEB82C04CCA929AC9284C0F2F3BB0D5 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Get slot info... a Select info source... boot_a [2000000] Ok SW: TECNO/BD4a-OP/TECNO-BD4a:11/RP1A.200720.011/230816V299:user/release-keys Product Brand: TECNO Product Device: TECNO-BD4a Product Model: TECNO BD4a Product Name: BD4a-OP Patch Level: RP1A.200720.011 Display ID: BD4a-XQ656SFGH-RGo-OP-230816V299 SW Version: 230816V299 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-08-05 Build Time: 16/08/2023 12:07:39 م CPU: armeabi-v7a,armeabi Product Info: bd4a_xq656 SW: vnd_bd4a_xq656-user 11 RP1A.200720.011 405833 release-keys Product Board: TECNO-BD4a Board Platform: mt6761 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] SmartInfo: Android Ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6761__840355F076826B1CBC349605D9F96069\ Items to check: 22 Read [16] NVRAM Read [8] NVDATA Read [3] PROINFO Read [7] NVCFG Read [11] PROTECT1 Read [1] PGPT Read [14] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6761__840355F076826B1CBC349605D9F96069\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__840355F076826B1CBC349605D9F96069.7z Verified Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:56 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
01-21-2024, 18:31 | #75763 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-BD4a Frp Code: SW: TECNO/BD4a-OP/TECNO-BD4a:11/RP1A.200720.011/230616V287:user/release-keys Product Brand: TECNO Product Device: TECNO-BD4a Product Model: TECNO BD4a Product Name: BD4a-OP Patch Level: RP1A.200720.011 Display ID: BD4a-XQ656SFGH-RGo-OP-230616V287 SW Version: 230616V287 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-06-05 Build Time: 16/06/2023 8:28:35 am CPU: armeabi-v7a,armeabi Product Info: bd4a_xq656 SW: vnd_bd4a_xq656-user 11 RP1A.200720.011 356215 release-keys Product Board: TECNO-BD4a Board Platform: mt6761 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Firmware ID: MT6761_TECNO_MOBILE_LIMITED_TECNO_BD4a_OSv11_BD4a-XQ656SFGH-RGo-OP-230616V287_RP1A.200720.011_bd4a_xq656 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xB9 Size: 0x0AC99C State: Ok WiFi MAC: AA006E742F76 BlTh MAC: 8077A49081FE IMEI[1]: IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6761 preloader_bd4a_xq656.bin with 3 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_bd4a_xq656.bin Reset port... Done: 00:00:24 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.51 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [-] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM12) MODE [0]: PRELOADER PORT; PORT: 12 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 572455D0D1031E5772DD21A9A5859D48391442656382271584077884CB560DBC IRG: 0x00000080 AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\auth_sv5.auth Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 700100544A3330333201042608C6491D EMMC crc Ok Ven: Kingston OEM: 256 ID: 544A33303332 [TJ3032] PRV: 0x01 SNN: 69601478 [0x042608C6] MM/YY: 4/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x748000000 [ 29.13 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: E6F3450A2758B7B3DB904C1EC42DFD97 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Strategy: [none|generic] Stage: Android OS [1] PROTECTION... Ok Stage: FRP... FRP is Off Reset port... Trying to reboot... Done: 00:00:24 Reconnect Power/Cable now |
01-21-2024, 23:11 | #75764 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | TECNO BD4a FRP Done Infinity CM2MT2 v2.53a6 Code: Operation: Reset Settings/Format FS [ v2.53a6 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... - Power device Off - Connect test-point if need - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V2023 (Android) (COM56) MODE [0]: PRELOADER PORT; PORT: 56 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: BCC7384ECAB9A763EF1E6BEEBE28857CF3B1C16DA507B41FA08C23AB23E7970C IRG: 0x00000080 AGENT: AUTO: Tecno: 2023-11 [d0ad8d98] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\MTK_AllInOne_DA_BR.bin [f835e4ca] C:\InfinityBox\CM2MT2\boot\Infinix\2023-11\auth_sv5.auth Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 700100544A333033320177510FFB8843 crc Ok Vendor: Kingston OEM: 256 ID: 544A33303332 [TJ3032] PRV: 0x01 Serial: 2001801211 0x77510FFB MM/YY: 8/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x748000000 [ 29.13 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 27AEAB7BA01C6C44169AAF1BBEEC3BA1 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 48 Get slot info... a Select info source... [vendor_boot_a] [boot_a] Ok SW: TECNO/BD4a-OP/TECNO-BD4a:11/RP1A.200720.011/231114V311:user/release-keys Product Brand: TECNO Product Device: TECNO-BD4a Product Model: TECNO BD4a Product Name: BD4a-OP Patch Level: RP1A.200720.011 Display ID: BD4a-XQ656SFGH-RGo-OP-231114V311 SW Version: 231114V311 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-11-05 Build Time: 14.11.2023 13:47:39 CPU: armeabi-v7a,armeabi Product Info: bd4a_xq656 SW: vnd_bd4a_xq656-user 11 RP1A.200720.011 479283 release-keys Product Board: TECNO-BD4a Board Platform: mt6761 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] SmartInfo: Android Ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__EAE812DCD7C1D57C855CF50ED7865D2F Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:33 |
The Following User Says Thank You to localizator For This Useful Post: |
01-22-2024, 07:41 | #75765 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | iTel L6503 Operation: Connect [sc9863a Boot FireFly] [v2.21a4 (beta)] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM21) vid: 0x1782 pid: 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? Loader exec Ok Dev UID: a04b1d3806111e4f4c03a28eda3040fece180c6b67734e4f45 845226130a70f2 get storage info... EMMC cid: 150100445036384D42023413CCF1C7E1 crc Ok Vendor: Samsung OEM: 256 ID: 445036384D42 [DP68MB] PRV: 0x02 Serial: 873712881 0x3413CCF1 MM/YY: 12/2020 CSD: D02701320F5903FFF6DBFFEF8E404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 ERASE_GROUP_DEF: 0x 0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 SIZE: 0x00400000 4.00 Mb WP_GRP_SIZE: 0x00800000 8.00 Mb RPMB size: 0x01000000 16.00 Mb SIZE: Market 64 Gb SIZE: Actual 0xE8F800000 58.24 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\sc9863_a04b1d 3806111e4f_extcsd_0015-Samsung_DP68MB_5.1_2024-01-22.bin Verify config values... Ok get partitions... Partitions: 44 items Connected Operation: Reset Settings / Format FS [sc9863a Boot FireFly] [v2.21a4 (beta)] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sc9863_a04b1d3806111e 4f\ Stage: FRP... Looking for items... 1 item(s) found [1] Writing... Ok Completed Stage: Userdata... [1] Format... Ok 516 us [2] Format... Ok 3 sec [3] Format... Ok 4 sec Completed Stage: Smart... [16] Format... Ok [17] Format... Ok Completed Finished 11 sec |
