10-16-2017, 13:35 | #45601 (permalink) | |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile b65 reset passworld done with king infinity cm2 QMOBILE B65 RESET PASSWORLD DONE WITH KING INFINITY CM2 Quote:
If You Like My Post Press Thanks Br ShahiD | |
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post: |
10-16-2017, 14:45 | #45602 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37f FRP Reset Done With King Infinity CM2 Card found : A19EC787 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Read PatternLock [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 23CDB98F ID_BLOCK_I : 007050E1 ID_BLOCK_L : 14EC8670DF4B70732C01F3DC1B66EEDE ID_BLOCK_L : 84FF41E8ED74E66F624D06FFF5383615 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 5689 Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to azhergoga007 For This Useful Post: |
10-16-2017, 14:54 | #45603 (permalink) | |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile e400 pro reset password done with king infinity cm2 QMOBILE E400 PRO RESET PASSWORD DONE WITH KING INFINITY CM2 Quote:
10-16-2017, 14:57 | #45604 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | samsung j910FN clone hang on logo recovered with great tool cm2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42014618D0F1B021 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42014618D0F1B021 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD4F31DC16CC0372325EEEDD37E78B1A6 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : j7209 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4028 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E2620000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:13 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:24 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:01 Reconnect Power/Cable! |
The Following User Says Thank You to shazzmob For This Useful Post: |
10-16-2017, 15:01 | #45605 (permalink) | |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile power 1000 reset password done with king infinity cm2 QMOBILE POWER 1000 RESET PASSWORD DONE WITH KING INFINITY CM2 Quote:
10-16-2017, 19:25 | #45606 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | INFINIX HOT V2 CLONE READ FLASH DONE BY CM2 Operation : Check/Read Info [ v1.27 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : CP8712 Model Brand : Infinix Model Device: CP8712 AndrVersion : 6.1 BaseBand CPU: SP9630EA CompileDate : 15-Mar-16 1:00:04 PM Project Ver : 6.1.009.P2.170228.hot-V2 Model Ext : Infinix hot-V2 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:20 Reconnect Power/Cable! Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : CP8712 Model Brand : Infinix Model Device: CP8712 AndrVersion : 6.1 BaseBand CPU: SP9630EA Project Ver : 6.1.009.P2.170228.hot-V2 Model Ext : Infinix hot-V2 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_tl.bin [Read Ok] : sharkl_cp1.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : PM_arm7_sys.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Build Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : ylparams.bin [Read Ok] : vbatlogo.bin [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1084 MiB Saved to : C:\Users\Yuslam Unique\Desktop\SP Backup\SP9630EA_CP8712_6.1_6.1.009.P2.170228.hot-V2_Infinix_hot-V2\ Done! Elapsed: 00:05:13 Reconnect Power/Cable! YUSLAM UNIQUE VENTURES ...it's all about progress |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
10-17-2017, 07:08 | #45607 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile L1 SPD6531 Logo Stuck Recover DOne With Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post: |
10-17-2017, 07:35 | #45608 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I5i MT6580 Logo Stuck Recover DOne By Formaate Only With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404050FA123F181F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404050FA123F181F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3950FF4FEB78375F03554AF8E08 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
10-17-2017, 08:30 | #45609 (permalink) |
Freak Poster Join Date: Oct 2016 Location: World
Member: 2635143 Status: Offline Thanks Meter: 166 | ZTE Blade V7 - Unlock Done !!!!! Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 187 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A01906532474145510705174F3C2D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050751452D3C5317 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x3A0E6C10F77970326B506DED400CDED8 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! ZTE Blade V7 - Unlock Done !!!!! |
The Following 4 Users Say Thank You to Dr FlasH For This Useful Post: |
10-17-2017, 10:03 | #45610 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | PANASONIC P55 PATTERN LOCK REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK (PANASONIC P55)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A2030504C5A10579 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A27905A1C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xFD096D45E17AA296F1C7387F28E1A3B0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Panasonic ProdName : P55 ProdModel : Panasonic P55 Device : P55 AndroidVer: 4.4.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.KK1.MP5.V1.5 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXX BTMAC Addr : XXXXXXXXXX WiFi MAC : XXXXXXXXXX MODEM : BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V47_1_3g_n EXTRA : LCD [0] : hx8394a01_dsi_ld_lg LCD [1] : hx8394a01_dsi_ys_lg LCD [2] : hx8394a01_6589_hd_dsi_boe LCD [3] : hx8394a01_dsi_ys_cmi LCD [4] : otm1283a_boe_auo LCD Res : 1280 #800x720 #480 TOUCH [0] : GT9XX CAM [0] : ov5648_mipi_raw CAM [1] : gc2235mipi_raw MODEM : yulong89_wet_kk_md1_hspa LOCALE : en_US en_GB en_IN hi_IN in_ID de_DE es_ES fr_FR it_IT pt_PT vi_VN ar_IL th_TH bn_IN ja_JP zh_CN zh_TW tl_PH fa_IR ur_PK nl_NL pl_PL tr_TR ru_RU uk_UA af_ZA sw_TZ zu_ZA fr_BE nl_BE hdpi mdpi Done! Elapsed: 00:00:11 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A2030504C5A10579 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A27905A1C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xFD096D45E17AA296F1C7387F28E1A3B0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
10-17-2017, 11:04 | #45611 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X6 3G SPD7715 NAND Patrren Reset Done With Great Infinioty CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC7715] NAND [Generic] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
10-17-2017, 11:18 | #45612 (permalink) |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | rivo b10 flash done Card found : S/N : 963CDDB0 , v0136 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.00 Load : SC6533G_4MiB_sc6533g_XS35_E08_A_E08_A_RIVO_V03_201 7-05-23_135101.ilod Device Info Details : [0] : sc6533g_XS35_E08_A [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_hs8292u [5] : flsh_spi32m [6] : nv3029e/st7789/gc9304c/gc9305/ili9325/ili9341/gc9306/LGDP4535 [7] : bf3a01serial/gc6123/gc6133/sp0820 [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2017-05-23_13:51:01 [12] : E08_A_RIVO_V03 Load Ok! Operation : Flash [ v1.00 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Flashing MCU code area Region Flash done! Flashing USERDATA code area Region Flash done! Programming completed! Done! Elapsed: 00:00:51 Reconnect Power/Cable! |
The Following User Says Thank You to jawad_anis For This Useful Post: |
10-17-2017, 11:18 | #45613 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | Halotel H8401 NETWORK UNLOCK DONE BY INFINITY CM2 Card found : S/N : AAA97BB6 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1101003030344745300116268B4B4275 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 1101003030344745300116268B4B4275 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD2FF4FA493522D49AEAB88CBD4B283B3 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Halotel ProdName : Halotel H8401 ProdModel : Halotel H8401 Device : Halotel H8401 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : Halotel_H8401_Ver08_20150629_1720 SECURITY : IMEI_SW [1] : 866XXXXXXXXXX IMEI_SW [2] : 866XXXXXXXXXX MAC Addr : 40D3952F1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_P2_1_wg_n EXTRA : LCD [0] : hx8379c_dsi_vdo_wvga LCD [1] : ili9806e_dsi_vdo_wvga LCD [2] : otm8019a_dsi_vdo_wvga LCD Res : 800x480 TOUCH [0] : ft5306 CAM [0] : gc2145_mipi_yuv CAM [1] : gc2155_mipi_yuv CAM [2] : sp2529_mipi_yuv CAM [3] : gc0329_yuv CAM [4] : sp0a10_yuv MODEM : hexing_cwet_kk_wg_18_t818_lock LOCALE : sw_TZ pt_PT en_US es_ES zh_CN de_DE zh_TW ru_RU pt_BR fr_FR tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1101003030344745300116268B4B4275 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 1101003030344745300116268B4B4275 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD2FF4FA493522D49AEAB88CBD4B283B3 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to bright hlatini For This Useful Post: |
10-17-2017, 12:16 | #45614 (permalink) |
Freak Poster Join Date: Aug 2016 Location: out of world
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | CPH1607 pattern remove done 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : D25FD0AE ID_BLOCK_I : 000460E1 ID_BLOCK_L : 677ABA3C6D0F681B96C435A407EE60C7 ID_BLOCK_L : F2B7CB2D56257C600928CC625F3692C0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following User Says Thank You to applebricks For This Useful Post: |
