07-30-2008, 18:31 | #1 (permalink) |
Freak Poster Join Date: May 2005
Member: 145289 Status: Offline Thanks Meter: 35 | Sucessfully kp215 unlocked by infinity Device: LG-MG296 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 20880EFFFFFFFF:20880E00000000 flash: ST Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 3599********* file saved: C:\Arquivos de programas\InfinityBox\LGA\eeprom_30_LG-MG296_20080730-141903.B1E.bin .................................................. .............. Check flash Done Check space... current eeprom imei: 359955 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 62 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to hakkothebest For This Useful Post: |
08-01-2008, 21:26 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @hakkothebest Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. @celusoft v 3.3 Just run Infinity-Box Shell, select required model and you will see pinout/cable information |
08-07-2008, 23:30 | #4 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: Guatemala
Member: 576278 Status: Offline Thanks Meter: 33 | Quote:
Thank you very much Very good contribution, I'll try and story you later, no longer makes stamina to do one , | |
Lg ke850 ***** sucessfully unlocked by infinity-box:)- | sahil2000ind | Infinity-Box | 8 | 10-21-2009 22:39 |
Lg Kp215 unlock by infinty | flasher12 | Infinity-Box | 2 | 11-15-2008 15:09 |
Alcatel E160 Sucessfully Unlocked By Infinity | Chennairam | Infinity-Box | 1 | 10-31-2007 13:13 |
w375 unlock by infinity ... post results here.. | ZIYAAD STRYKER | Infinity-Box | 2 | 05-13-2007 19:46 |
we want bb5 unlocking by infinity | shantilal | Infinity-Box | 26 | 12-14-2006 10:13 |
