06-28-2009, 08:56 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Lg ke850 ***** sucessfully unlocked by infinity-box:)- module v1.68 Device: LG-KE850 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static_20090628-131915.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static2_20090628-131916.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-security_35030526000000100_20090628-131917.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_35030526000000100_20090628-131918.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01E4 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 17 sec Remove/Install battery now ! Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KE850CP40FL-61-V10a-505-03 APR 15 2008+0 imei: 35342601689295200 Done Finished WBR sahil2000ind |
The Following 4 Users Say Thank You to sahil2000ind For This Useful Post: |
06-28-2009, 19:11 | #3 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | that's good. any other successfully unlock KE850 ***** ? i try to unlock one: - Infinity can't read unlock code and IMEI; - Infinity make direct unlock and phone is still locked; - Infinity write other eeprom-s and make direct unlock and read codes (on some eeproms can read IMEI and unlock code but is wrong), phone still locked. and finaly phone is still locked possible solution is to buy other tool za LG. |
08-12-2009, 09:27 | #4 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Tirupati-India Age: 49
Member: 48156 Status: Offline Thanks Meter: 127 | COM4 [VCP0] selected module v1.66 Device: LG-KE850 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static_20090812-135547.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static2_20090812-135547.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-security_35030526000000100_20090812-135549.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_35030526000000100_20090812-135550.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01E8 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 33 sec Remove/Install battery now ! |
The Following User Says Thank You to SR-sigma For This Useful Post: |
Which program to use to unlock LG KE850 ***** | gbyss | LG | 4 | 08-22-2009 06:53 |
lg ke850 ***** revived by fg..... | bbaj | FuriousGold | 4 | 01-11-2009 09:39 |
LG KE850 ***** Dead after try to unlock | samuelscu | LG | 4 | 05-14-2008 07:17 |
Alcatel E160 Sucessfully Unlocked By Infinity | Chennairam | Infinity-Box | 1 | 10-31-2007 13:13 |
Lg Ke850 ***** Unlocking | ferre | LG | 4 | 07-29-2007 14:28 |
