10-07-2008, 20:50 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! as long as noone is answering, i can teach how to find pinout by youreslf: 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
does padfinder support CECT C1000-SPD? | lorenzo roberto | PadFinder box | 0 | 07-13-2009 07:21 |
did infinity support cect c1000 spreadtrum | RAHUL_CELLCARE | Infinity-Box | 1 | 03-03-2009 17:44 |
infinity support cect n95 pinout help | pkghosh1 | Infinity-Box | 12 | 07-30-2008 11:01 |
please support cect-168 | IBMOBILES | Chinese Cocktail | 11 | 07-15-2008 21:53 |
infinity-box support cect v8? | dimitron | Infinity-Box | 3 | 06-24-2007 14:33 |
