01-13-2008, 17:11 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market, f.e. exist at least 20 phones with name "Chinese Nokia-N95" but with different bottom connectors and different pinouts, so we recommend you to include the next information in your question regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
01-13-2008, 21:24 | #4 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 367027 Status: Offline Thanks Meter: 50 | Thank u For ur reply Sir it has mini usb 5*2 connector.sir i will post the pcb .i have a usb cable .can i find rx and tx on it.one wire connected by two port and two are connected by other two ports.i thing 1st gnd. |
01-14-2008, 13:47 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! no any sign of test points on first phone. I am sure you must look for tx/rx pins in system connector. for second phone worth to try 6 testpoints near sim connector. |
01-16-2008, 13:55 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! check with multimeter if GND pin is located on same place as on picture if yes- try to change tx, rx wires from box with places and try again |
02-07-2008, 10:30 | #11 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: somewhere in KENYA
Member: 648607 Status: Offline Sonork: 100.1638674 Thanks Meter: 23 | Cant Flash Any Chinise Miracle. Quote:
02-07-2008, 23:39 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello joseck! why flash? what problem with phone? maybe just format FFS will be enough to solve your problem? first of all you must find pinout for your phone. for doing this check where is located GND pin in your system connector. Check for it in cable selector or use "search" in this forum. if will not find- request it here |
did infinity support cect c1000 spreadtrum | RAHUL_CELLCARE | Infinity-Box | 1 | 03-03-2009 17:44 |
Cect n95 dead help | That'sme | Infinity-Box | 4 | 01-17-2009 18:40 |
I Need Cect N95 Pinouts | jalalmz | Infinity-Box | 2 | 01-02-2008 10:12 |
