Old 08-16-2015, 07:40   #1 (permalink)
lionfinger2007's Avatar
Member: 576282
Thanks Meter: 145
tecno h6 flashed but not coming on, please what to do?
This phone was not coming on and I flashed it, it flashed complete but still not coming on, what could be the problem?
Below is flashing log;
Card found: S/N B25B:0128
Chinese Miracle II [MTK module] v 1.24
Scatter Load Ok , BaseBand : MT6582 , Project : ratech82_cwet_rlk_kk , Storage : EMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
Operation : Flash [ v1.24 ]
======= Flash
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 150100513758534142016B77E7E681BB
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BASX7
[eMMC] : FLASH_CID : 150100513758534142016B77E7E681BB
[eMMC] : FLASH_LEN : 0x00000001D2000000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : ratech82_cwet_rlk_kk , Storage : EMMC
Setting : AFF verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000000000-0x0000000000100000
Erase : 0x0000000001D00000-0x000000014B280000
Flash Pre-Erase Done, time used : 00:00:09
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_ratech82_cwet_rlk_kk.bin
Preloader Sent , Init passed
PartCount : 0014
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:05:42
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:06
Update RomInfo done
Done!
Elapsed: 00:06:17
Reconnect Power/Cable!
Old 08-16-2015, 08:26   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. By the log all seems as ok.
Try flash also with SPFT to make sure in correct ( I still not test enough 6582 ) , and if same - erase phone and reflash. Make NVRAM backup before.
Old 08-16-2015, 11:37   #3 (permalink)
Member: 576282
Thanks Meter: 145
Thanks, but please what is SPFT and how will I use that?
Old 08-16-2015, 12:34   #4 (permalink)
JayDi's Avatar
Member: 462970
SP Flash Tool. Use v5.14xx or newer. CM2 read files, which compatible with SPFT fully.
Old 08-18-2015, 09:43   #5 (permalink)
Member: 576282
Thanks Meter: 145
Thanks, it worked with SP-Flash-Tool-v5.1528.00 and the phone is coming on now and working fine.
Others, please you can get the setup here
Old 08-18-2015, 11:58   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks for info about result.
Unfortunately - just phisycally and financial sides can't allow me collect much different samples to test all. If you will face any branded model ( like alcatel and e.t.c. , which are WW and possible find it in Europe/Asia - then I can get it.
Old 08-19-2015, 09:27   #7 (permalink)
Member: 576282
Thanks Meter: 145
What you mean by "which are WW "?
Old 08-19-2015, 09:35   #8 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
WW stands here for World Wide.
Br.
Page generated in 0.21945 seconds with 8 queries
