12-17-2011, 11:48 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 714594 Status: Offline Thanks Meter: 2 | touchscreen calibration failed LOG COM5 [VCP0] selected module v4.10 Action: touchscreen calibration mode: 1 Calibration order: reverse Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: M10AW1108 Version: MT53C_10A_GEMINIPLUS_HW detecting structure #2... 0 1 2 3 4 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41error: detection failed (40 tries), read flash and send to support connection Ok detecting structure #5 (mode-1)... 18 15 14 13 12 10 8 4 3 2 0error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! this file back up a_team_pcb01_gprs_mt6253_s00.m10aw1108.bin_flnpf38 f3050m0y3dh__full¶ flash_20111201-122129.b0m |
The Following User Says Thank You to SPYDERCELL2 For This Useful Post: |
12-21-2011, 11:30 | #3 (permalink) | |
Member: 714594 Status: Offline Thanks Meter: 2 | Quote:
this log COM5 [VCP0] selected module v4.10 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... A_TEAM_PCB01_GPRS_MT6253_S00.M10AW1108.BIN_FLNPF38 F3050M0Y3DH__fullflash_20111201-122129.B0M.bin loaded error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 32 sec Remove/Install battery now ! please help me | |
12-21-2011, 14:51 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again If still face same problem after doing this then you need to write eeprom and then repeat the calibration process. Wr. |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
In wintesla 3310, what does cobba parrarel failed means | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-18-2001 16:05 |
rf calibration of 8850-wintesla | tagheuer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-07-2001 05:25 |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
