07-25-2018, 20:24 | #2 (permalink) | |
Freak Poster Join Date: Jan 2013 Location: RUSSIA
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | solution for this matter!!! Quote: - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 25-Jul-2018; Expired: 26-Jul-2019; Support: Active https://yadi.sk/i/OlYs_0tX3ZZyFM | |
07-26-2018, 06:56 | #3 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | planetgsm Posts: 2 Joined: 25 Jul 2018, 19:51 Re: Smart-Card/Dongle/Box update Problems and Solutions Quote Post by planetgsm » 25 Jul 2018, 20:01 ==== [7/25/2018 21:27:26] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.72 [7/25/2018 21:27:47] === Searching... Card-Reader: FT SCR2000 0 HWID: 010675892488129 Box/Dongle found: [BEST] Serial No (S/N): Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0030 v.0228 => Activations: - 03: [BEST] v.0122 - 0A: #10 === DongleManager [Infinity] v1.72 [7/25/2018 21:27:52] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0106758924881292 Box/Dongle found: [BEST] Reading... Serial No (S/N): FBxxxxx Firmware version: 0122.02 === Process started: 7/25/2018 21:27:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Last APDU: 133 sec Card returned error - 0000 at 0/8391 Error upgrading applets: Card returned error - 0000 at 0/8391 Disconnected Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 25-Jul-2018; Expired: 26-Jul-2019; Support: Active Token - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 25-Jul-2018; Expired: 26-Jul-2019; Support: Active - Activation 2: Infinity [BEST]; S/N: Fxxxxxx; Firmware Version: 0122 - More Services may be active but not listed posted on tTHE infinity FORUM !!!none there also!! |
07-26-2018, 07:16 | #4 (permalink) | |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Need solutions fast please! Quote: Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.72 [7/25/2018 21:27:47] === Searching... Card-Reader: FT SCR2000 0 HWID: 010675892488129 Box/Dongle found: [BEST] Serial No (S/N): Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0030 v.0228 => Activations: - 03: [BEST] v.0122 - 0A: #10 === DongleManager [Infinity] v1.72 [7/25/2018 21:27:52] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0106758924881292 Box/Dongle found: [BEST] Reading... Serial No (S/N): FBxxxxx Firmware version: 0122.02 === Process started: 7/25/2018 21:27:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Last APDU: 133 sec Card returned error - 0000 at 0/8391 Error upgrading applets: Card returned error - 0000 at 0/8391 Disconnected Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 25-Jul-2018; Expired: 26-Jul-2019; Support: Active Token - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 25-Jul-2018; Expired: 26-Jul-2019; Support: Active - Activation 2: Infinity [BEST]; S/N: Fxxxxxx; Firmware Version: 0122 - More Services may be active but not listed posted on tTHE infinity FORUM !!!none there also!! | |
07-26-2018, 09:53 | #5 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
07-26-2018, 11:47 | #6 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | positive result by changing the dongle result === DongleManager [Infinity] v1.72 [7/26/2018 13:46:01] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0106758924881292 Box/Dongle found: [BEST] Reading... Serial No (S/N): xxxxxxx Firmware version: 0122.02 === Process started: 7/26/2018 13:46:06 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed === Process finished: 7/26/2018 13:46:26 === === DongleManager [Infinity] v1.72 [7/26/2018 13:46:26] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0106758924881292 Box/Dongle found: [BEST] Serial No (S/N): xxxxxx Firmware version: 0122.02 => Activations: - 00: Infinity-Box/Dongle v.0137 - 03: [BEST] v.0122 SOLUTION: 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware Last edited by soulgsm; 07-26-2018 at 11:53. |
