04-21-2019, 07:16 | #1216 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Nokia 1+ (ANTMAN) supported ( TA-1111, TA-1123, TA-1127, TA-1130 ) - Identify - Reset Settings / Format FS / Reset FRP - Firmware Flashing Other - FlashLoader datbase updated - Some bugfixes and changes https://www.infinity-box.com/support/?r=100071 |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
04-28-2019, 22:53 | #1217 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 MTK/Mediatek v2.06 - AutomaticBoot selection and other stuff To use this software Smart-Card firmware version should be 0137 or higher. Base: Base - Secure boot - Automatic boot selection feature released Base - Secure boot: Allow automatic detect boot configuration for SECURE enabled chips Base - Secure boot: Following secure configurations are supported: SBC, SLA, SDA and their combinations Base - Secure boot: Following secure configurations are NOT supported: ARB and combinations with it Base - Secure boot: Supported CPU: MT6572, MT6580, MT6582, MT6589, MT6592, MT6735, MT6752, MT6753, MT6755, MT6757, MT6763, MT6771, MT8127, MT8135, MT8167 ( list of tested ) Base - ModelBD - Manual Model DB update feature released Base - ModelBD: Allow save boot configuration in sw database for future use Base - ModelBD - Automatic Model DB update feature released Base - ModelBD: Allow save boot configuration in sw database for future use ( press and hold LCTRL key during press IDENTIFY ) Base - FlashLoader line v1904 tested and supported. Older lines (6592/6595 and similar) still unstable Base - FlashLoader line v1912 tested and supported. Older lines (6592/6595 and similar) still unstable FWFlasher: FWFlasher - Flash core updated FWFlasher - SecureFlash on Legacy phones revised FWFlasher - MT6771/6765 support revised FWReader: FWReader - More types supported for safe read FWReader - Info reading improved FWReader - packing revised FWReader - more accurate data verification Service: Service - Format FS revised Service - NVRAM module updated Platform: Platform - MT6765/MT6762 support optimized Loaders: LoaderDB - Lot of new agents included (Tecno, Tesla, Wiko and other) LoaderDB - Included MT6570 "DRAM Fixed" agents used to revive devices flashed with wrong preloader ( so called "Doogee X10 bug" ) Other: Other - Many different small changes and fixes Other - SaveUser Configuration option can be found in FILE system menu. Work only in MANUAL mode ! Other - ErrorHandling updated - more detailed hints/explanation of troubles during service process Other - Preloader tools, Preloader init and other related stuff updated Other - Partial LEGACY NAND support - optimized boot. Identify work complete if BMT autoset work correct Info: Automatic Boot option can be switched off/on in settings menu Info: Automatic Boot work in "SelfLearning" mode - once learned it will boot this type/device line after automatically Info: Automatic Boot option support and learn different modes ! Make sure if device used DIFFERENT settings - learn all of them ! Info: MT6570 Fixed NAND DA can be used for flashing FACTORY firmware and INIT PRELOADER. For FW read and all other things - use INFINITY ones ! How to use AutomaticBoot select, User DB, Auto DB |
The Following 5 Users Say Thank You to InfinityHelp For This Useful Post: |
05-06-2019, 09:27 | #1218 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.16 - Android 9 firmwares support, model finder - MTK flash engine updated ( Feature Line ) - MTK flash engine updated ( SmartPhone Line ) - Android 9P firmwares can not be flashed in Nokia 5.1/3.1/3.1+ , fixed - Model selector over TA/RM identifier activated. Double click on model to open required tab - Base Loader database updated Bugfixes and minor changes - Support New firmwares can be found on support for all supported lines https://www.infinity-box.com/support/?r=100074 |
05-29-2019, 05:36 | #1219 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 SPD/UniSoc - CM2SP2 - v2.00 r1 released - Supported platforms: SpreadTrum: SC5735 SC7715 SC7731C, SC7731G SC9820 SC9832A SC9850 SC9853i UniSoC: SC9820E SC7731E SC9832E SC9850K SC9850KH SC9863 - Support Generic (Non-Secure), SecureV1, SecureV2 devices Android 4/5/6/7/8 versions - Supported operations in initial release: Identify ( include complete device info ) Reset Settings / Format FS Reset FRP Firmware flashing ( Safe Flash, Repartition, HW verify, Flash customizing ) - Database: Basic wide-range bootloaders for common devices types Also lot of other pre-defined models already included in database - Extra: Feature: Completely safe flash engine ( allow flash SimLock / Signed / and other devices, recover critical data from semi-damaged NV ) Feature: Automatic ModelDB update at new model detection ( loader select, pac load etc. ) Feature: Customized boot option and sources: Manual PAC, Manual FDL pair with automatic details detection, Pre-defined DB, Self-Learning DB Feature: Complete Firmware Info detection at FW load with extended info https://www.infinity-box.com/support/?r=100077 |
The Following 6 Users Say Thank You to YellowBoss For This Useful Post: |
06-06-2019, 12:12 | #1220 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 SPD/UniSoc - CM2SP2 - v2.00 r2 released - More models and features - Core Protocol updated Connection problems with older drivers revisions fixed - Service Identify - Read Security info option enabled > Read and verify NV state, show security info Identify - Userdata state detection optimized Format FS - New FMT mode - Forced. Use it if you have problems with default ones. FRP NOT in touch on that mode! - Flasher Optimized PAC handling Some old device types flashing fixed ( SC7715/SC7731 ) NVManager updated - optimized verification, optimized data recovery in case of NVM damaged, complete security info display Forced NVM update option activated ( complete NV rewrite with all calibration data destroy, if device NVM completely damaged ) - Database: New generic boots included for SC9850KA, SC9850, SC9832E, SC9820 - Other Bug fixes and some changes according users requests https://www.infinity-box.com/support/?r=100078 |
07-25-2019, 09:53 | #1221 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.17 - All New and Old HMD support activated HMD N 1 ** TA-1060, TA-1056, TA-1047, TA-1079, TA-1066 HMD N 1 Plus ** TA-1130, TA-1123, TA-1111, TA-1127 HMD N 2 * TA-1035, A-1029, TA-1023, TA-1011, TA-1007 HMD N 2.1 * TA-1086, TA-1084, TA-1092, TA-1093, TA-1080 HMD N 2.2 ** TA-1183, TA-1184, TA-1188 HMD N 3 ** TA-1028, TA-1038, TA-1032, TA-1020 HMD N 3.1 ** TA-1074, A-1070, TA-1063, TA-1057, TA-1049 HMD N 3.1 Plus ** TA-1125, TA-1124, TA-1118, TA-1117, TA-1115, TA-1113, TA-1104 HMD N 3.2 * TA-1154, TA-1156, TA-1159, TA-1161, TA-1164 HMD N 4.2 * TA-1133, TA-1149, TA-1150, TA-1152, TA-1157 HMD N 5 * TA-1044, TA-1027, TA-1024, TA-1053 HMD N 5.1 ** TA-1088, TA-1081, TA-1075, TA-1061 HMD N 5.1 Plus ** TA-1120, TA-1112, TA-1108, TA-1105, TA-1102 HMD N 6 * TA-1033, TA-1039, TA-1025, TA-1021, TA-1000, TA-1003 HMD N 6.1 * TA-1043, TA-1016, TA-1045, TA-1050, TA-1054, TA-1068, TA-1089 HMD N 6.1 Plus * TA-1116, TA-1103, TA-1083 HMD N 7 * TA-1041 HMD N 7.1 * TA-1100, TA-1096, TA-1095, TA-1085 HMD N 7 Plus * TA-1062, TA-1062, TA-1055, TA-1046 HMD N 8 * TA-1012, TA-1004, TA-1052 HMD N 8.1 * TA-1128, TA-1121, TA-1119 HMD N 8 Sirocco * TA-1042, TA-1005 HMD N 9 PureView * TA-1094, TA-1087, TA-1082 HMD N X71 * TA-1172 For now the next features are supported: > Firmware flashing ( Factory / BEST firmware packages ) > Format FS / Reset Settings > Reset FRP > Identify Info marks: * - Device require Remote Authentification Server ( credit cost - 0 for now ) ** - Device supported / supported already STANDALONE - Base Support for old HMD line over RAS for QCOM models Support for new HMD line - WT/HQ activated - 2.2, 3.2, 4.2 ( over RAS for QCOM models ) Loader database updated ModelFinder updated FileSystem toolkit updated, changed FormatFS for all SP lines SW/HW/Cross-avoid check activated for BL update mode Bugfixes and minor changes - MTK SP Updated loader database Boot log now show also ARB state and other service info Automatic backup for critical partitions activated - MTK FP SWVersion check revised FlashEngine updated FileSystem (Forensic) engine updated - SPD FP Backup / Restore security activated FlashEngine revised - Support Some firmwares for wide range of QCOM/MTK HMD Smartphones can be found on support area https://www.infinity-box.com/support/?r=100081 |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
07-25-2019, 13:20 | #1222 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.18 - important fix for v1.17 You can download complete v1.18 package as well as v1.18-exe-only if you have v1.17 installed - Base Flash engine revised ( N 2/2.1/5/6 flashing fixed ) Format FS / FRP reset revised Other minor changes and fixed https://www.infinity-box.com/support/?r=100081 |
10-08-2019, 09:51 | #1223 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 SPD/UniSoc v2.01 - UniReader Edition - Android 4-5-6-7-8-9 As ordinary, Infintiy Team continue to release unique and world-first software features, algorithms and methods. - Core Protocol updated Alternate protocol support activated ( automatic switch depends on model ) - New Self-Learning engine for semi-supported devices ! In case of problem with device servicing - during identify session SW will make new database record That record available from boot menu after that to use exactly for this device line That will fix any incompatibility loader <-> device problems and remove any servicing issues - Service Identify - better structure detection, simlock state info Identify - Userdata state detection optimized Format FS - Forced Format revised - Flasher Optimized PAC handling Optimized older device line support ( Sc7715-Sc9832 from SPRD ) NVManager updated - Identify, Security swap and verification, Recovery mode Activated flashing of own FlashFile format files made by FWReader - Firmware Reader activated! Allow read ANY security level phone from Spreadtrum or UniSoc on almost all Android OS versions! Support OLD SPRD line devices: SC7715, SC7731, SC9820, SC9832, SC9850 and their revisions and modifications Plain, Signed and RSA-enabled Android 4, Android 5, Android 6, Android 7 lines are supported (higher versions were NOT released from SPRD) Support NEW UniSoc line devices: SC7731E,SC9832E,SC9863,SC9850,SC9820E and their revisions and modifications Plain, Signed and RSA-enabled Android 6, Android 7, Android 8, Android 9 lines are supported (lower versions were NOT released from UniSoc) Arch32/Arch64 support Support "SPRD"-like chipsets with Intel X86 arch SC9853I and its modifications and revisions Plain, Signed and RSA-enabled Android 6, Android 7, Android 8 lines are supported It is the only existing and complete solution Additional info: Firmware use OWN format. Firmware is COMPLETE one, allow to fix any sw-related state including FlashChip erase, change or complete SW rebuild Unlike older SWReader version used in V1 line there is no need in bunch of additional re-connection operations or to make something special. - Database: New generic boots included, some boots updated - Other Bug fixes and some changes according users requests - Known issues: [1] UniSoc line is SLOW. It is VERY SLOW! Unlike SPRD ones, it consume x4-x5-x6 more time comparing to old SPRD. We made almost all possible for now to speed it up. And that is limit for protocol. In near time it should be some speed up to 20-30% but this solution still require some more time. [2] UniSoc devices with ARB active may dead on wrong SW version flashing at Android 9 line. We checking that issue and collecting samples. According users test and reports solution will follow. [3] Some old devices after FW flashing may gone to "Encryption Unsuccessfull" state, right now - "ResetPhone" button enough. [4] Sw will try always, in any case retrieve all device-side keys/security during flashing and identify, if they exists inside. Much backups better, that nothing. Actual for devices with paired/signed security and/or active keybox. [5] NAND devices on SC9820,SC7715,SC8830 not supported yet for FW reading https://www.infinity-box.com/support/?r=100084 |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
10-15-2019, 09:42 | #1224 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle II SCR/SPD-RDA v1.05 - New models and features As ordinary, Infintiy Team continue to release unique and world-first software features, algorithms and methods. Supported CPU list: Spreadtrum: SC6530, SC6531, SC6531(A/C/D) UniSoc: SC6531E, SC6533, SC6533G RDA Mirco: RDA8851 rev A,B,C,L,CL RDA Micro: RDA8826 RDA Mirco RDA8851 rev A,B,C,L,CL RDA Micro RDA8826 Spreadtrum SC6533/G: Updated LOD tools ( Factory LOD support revised ) UserCode reading improved Spreadtrum/UniSoc SC6530/6531/A/C/D/E: New feature activated: Complete identification During Binary Dump selection SW will extract complete device info ( build version, time, HW details etc. ) During PAC file selection SW will extract complete device info ( build version, time, HW details etc. ) During Flash Reading SW will extract complete device info ( build version, time, HW details etc. ) Readout naming changed to DeviceInfo details instead of flash size/flash vendor Repair security revised Database revised, loaders updated ( extended range of supported SC6531EFM devices with 4-8MB flash ) Spreadtrum/UniSoc other: Protocol updated, error codes handling activated SC6531 with 16MB flash support revised FTM during flashing now make DNVM clean, FS clean and structure verification UserCode reading improved Some other bugfixes and small changes Info: "HardLock" detection feature for SP-locked device activated under test https://www.infinity-box.com/support/?r=100086 |
10-27-2019, 07:53 | #1225 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 SPD/UniSoc v2.02 - Android9, Privacy, New models and features - Core Protocol updated Error handling, error explanation and hint module activated SC9850 and similar devices WRITEFLASH security disable option enabled > Use for custom / forced / service operation on secure-enabled SC9850 phones (in case of "AC SECURITY" error) - Android 9 line devices tested and supported for Firmware reading! - Self-Learning mode for Firmware Reader activated! That feature allow analyze new and unknown devices "on the fly" and make complete and correct firmware Just follow the SW instructions if need and you don't need to wait updates for latest devices - Service Security - NVM reading feature activated > Allow read complete device factory calibration data, security items > Save also modem info for cross-writing NV between different models Security - NVM writing feature activated > Allow restore / rewrite device factory calibration data, security items > Allow use different modes during restore: > 1. SWAP ( safe mode ) - if security alive SW will try swap security data > 2. Complete restore ( rebuild mode ) - destroy ALL original security data if it was inside phone Identify - better structure detection Identify - BaseBand deep identification > Allow read complete BaseBand info and read "MODEM TAG" > Since nowdays there much SAME devices under DIFFERENT names but same by RADIO part - you may use NVM according that TAG > TAG now saved during NVM read operation, you can use default Windows search bar in Backup folder to seek need TAG UserData - PrivacyLock read feature activated > Allow read PRIVACY lock password and details > Support DIFFERENT models made by OEM "TRANSSION" - Flasher Optimized speed ( from 5% to 15% for UniSoc line ) Optimized PAC handling Optimized older device line support ( SC7731GEA and similar from SPRD ) NVManager updated - Identify, Backup, Security swap, Verification Activated new option - Re-Sparse. > Allow prepare big filesystem images before flash. Useful for low-ram devices and adnroid 9 devices > Use that option, if have face "INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL!" error during SYSTEM flashing - Firmware Reader Android 9 line support finished, completely tested and confirmead as working Vendor-specific mode activated. SW will identify "non-standard" devices and make firmware complete and correct now > FOTA, vendor-specific features and rest stuff has been tested - Database: New generic boots included for SC7731C/G New generic boots included for SC9863 ZTE lines devices included - A5(2019), A7(2019), L130, L8 and some others - Other Bug fixes and some changes according users requests - Known issues : [1] UniSoc line is SLOW. It is VERY SLOW! It may takes up to 3-4 times more time comparing with old SPRD. [2] UniSoc devices with ARB active may dbe ead on wrong SW version flashing at Android 9 line. We are checking that issue and collecting samples. According to users test and reports solution will follow. [3] Some old devices after FW flashing may gone to "Encryption Unsuccessfull" state, right now - "ResetPhone" button enough. [4] UniProt option active may lead to FLASHING problems on old SC7715-SC7731 line devices. Disable this option if you have a problem with old SPRD [5] NAND devices on SC9820, SC7715, SC8830 are not supported yet for FW reading https://www.infinity-box.com/support/?r=100087 |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
11-18-2019, 12:12 | #1226 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.19 - New models and features https://www.infinity-box.com/support/?r=100088 |
11-24-2019, 19:45 | #1227 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Data Explorer v1.00 - Initial Release - Data extraction based on full reconstruction of file system - Initial features 1. Phonebook records extraction from dump 2. Phonebook records export to TXT, VCF formats 3. Memory type auto detection (Manual selection also supported) 4. File system parameters (sector size, header type) auto detection (Manual selection also supported) - Supported devices: MTK with NOR flash types, in most cases based on CPU types like MT625x, MT626x, and some MT622x https://www.infinity-box.com/support/?r=100089 |
11-27-2019, 12:56 | #1228 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 SPD/UniSoc v2.03 - Easy Identify, New models & features - Core Protocol updated Error handling, error explanation and hint module updated - Service NVM operations revized DiagMode option activated ( Platform -> Control -> DiagMode ) > Change SW mode to diag, instead of flash. Do not require BootSelection. Allow for now: 1. Identify Device - ModemInfo, Build Info, SecurityInfo, SOC Info, DeviceHW Info 2. Format FS / Reset settings ( NOT touch FRP! ) - WIPE mode 3. Read NV data, verify NV > Don't forget change SW mode between Service/Flash for those operations ! New Identify option - device Platform, Device HW details identification > Allow detect device SOC family, RAM amount for faster loader selection > Work in DiagMode, Work ON MODERN and UNISOC chipset only ! - Flasher Optimized flashing protocol Optimized older device line support NVManager updated - Identify, Backup, Security swap NVManager Recovery tool updated - Firmware Reader Optimized structure identification Activated "forced" reading. Option skip data verification. > In case of semi-damaged devices, if backup atleast of something required > In case of "Critical data damaged" errors Optimized data verification during create FW - Database: SC983xx generic loader DB updated SC9853i generic loader DB updated SC7731E generic loader DB updated SC7731x generic loader DB updated SC9863 loaders DB updated - BQ, Wiko, ZTE, Symphony SC7731c/g loaders DB updated - various models and RAM size SC9832E loaders DB updated - Meizu, Wiko Some other various models with specific hw settings included in loader DB - Other Boot Selection mode are indepedent ( loader base can be changed after FW selection, in Platform tab ) Bug fixes and changes according users requests - Special thanks to respected Mr. gracy_elec https://www.infinity-box.com/support/?r=100090 |
12-04-2019, 14:00 | #1229 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Data Explorer v1.01 - new features and improvements Data extraction based on full reconstruction of file system - NAND flash types are partially supported - Additional information extraction supported such as IMEI(s), User Code - More contacts types are supported - Open folder with result file(s) after finish: option can be enabled in `Settings` page - Minor bugs fixed https://www.infinity-box.com/support/?r=100089 |
12-16-2019, 19:26 | #1230 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Shell v1.52 released - models database updated - models database update procedure improved |
@-:=:-:=:-:=:-:=warning for UST-PRO2 TEAM -:=:-:=:-=:-@ | nejm | UST Pro II | 5 | 01-26-2010 09:30 |
30-04-2009 : Infinity Box Update : SAMSUNG CDMA Models Supported | Infinity-Box | Service Products News & Updates | 0 | 04-30-2009 14:46 |
..: Ultimate Unlockers - UPDATES & NEWS - Latest version: 3.07 :.. | Mizar | Cruiser Suite | 4 | 12-11-2008 12:01 |
Update 31 May : NEC E101 Chinese flash files : ST55 Flash files uploaded : | Infinity-Box | Infinity-Box | 2 | 07-26-2008 09:55 |
