05-11-2011, 10:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Republic of Kosova Age: 54
Member: 189304 Status: Offline Sonork: 100.1614605 Thanks Meter: 40 | ZTE X670 Lisbon dead if anybody can uploadit here i appriciate |
05-11-2011, 11:19 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I am sure that it's impossible to damage this phone with default unlock method. What you have tried to do with phone exactly ? Need honest and detailed explanation. |
05-11-2011, 17:43 | #3 (permalink) |
Member: 189304 Status: Offline Sonork: 100.1614605 Thanks Meter: 40 | hm,im one the first infinity users,i did all correct first try after unlock phone powered,second try with sim inside shows only shome leters on screen,after flashing nothing,but still can be flashed thats still something |
05-12-2011, 09:13 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | you can see readme.txt file in support area for this phone: Two types of X670 exist on market: 1. with 16 Mb flash chip 2. with 32 Mb flash chip so if you want to get any advice about your phone I suggest you to post operation logs first, in other case our discussion is useless. |
05-12-2011, 10:37 | #5 (permalink) | |
Member: 189304 Status: Offline Sonork: 100.1614605 Thanks Meter: 40 | Quote:
detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: B6BE70D2 rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN project-id: X670_V1_OG_Z2_FRES_DFFA111, 09457FC0 code offset: 00000000 ffs offset/size [02]: 01000000/01000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01000000 startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.B6BE70D2.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.B6BE70D2._ZTEMT25_09A _GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_OG_Z2_FRES_D FFA111.BIN_C07F4509_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.B6BE7 0D2.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.B6BE7 0D2._ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z2_FRES_DFFA111.BIN_C07F4509_.rpl ==================== warning: unknown firmware: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN_C07F4509 Unknown firmware found (v.3.80, database date: 20.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC227E22632260:18E59F00000000 Backup required data Done ====> Patch required data ... ................................................. lock area found ................................................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC227E22632260:18E59F00000000 flash: EC227E22632260:18E59F00000000 Write: lock-area-1 flash: EC227E22632260:18E59F00000000 flash: EC227E22632260:18E59F00000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 0 sec Remove/Install battery now ! Here it is: already flashed 3 times,unlock and other ops working still | |
05-13-2011, 11:31 | #7 (permalink) | |
module v3.80 Device: ZTE-X670_32mb Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware ZTE-X670_32mb_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00 .X670_V1_OG_Z3_ESFR_DFFA113_2010-10-27_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3F03:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: B6BE70D2 rom info ver: 07 sw version: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z2_FRES_DFFA111.BIN project-id: X670_V1_OG_Z2_FRES_DFFA111, 09457FC0 code offset: 00000000 ffs offset/size [02]: 01000000/01000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 01000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.B6BE70D2.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z3_ESFR_DFFA113.BIN_AD91882A].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.B6BE70D2._ZTEMT25_09A _GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_OG_Z3_ESFR_D FFA113.BIN_AD91882A_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.B6BE7 0D2.[ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z3_ESFR_DFFA113.BIN_AD91882A].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.B6BE7 0D2._ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670 _V1_OG_Z3_ESFR_DFFA113.BIN_AD91882A_.rpl ==================== warning: unknown firmware: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z3_ESFR_DFFA113.BIN_AD91882A Unknown firmware found (v.3.80, database date: 20.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00.X670_V1_O G_Z3_ESFR_DFFA113.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: EC227E22632260:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:18E59F00000000 Finalization Done Finished, time used: 11 min 35 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! No luck boss.seems i have to waitt for another pnone with same flash and do copy writte | |
05-13-2011, 18:06 | #11 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | Use: InfinityUpdate_MModule_v3.62 1 repair security area 2 flash with ZTE-X670_32mb_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00 .X670_V1_OG_Z2_FRES_DFFA111_2010-05-14_En_Fr_Es_Orange-Lisbon.B0M.bin (tick smart write and format ffs) 3 unlock with smart fast |
05-14-2011, 17:09 | #13 (permalink) |
No Life Poster Join Date: Apr 2007
Member: 488536 Status: Offline Thanks Meter: 36 | me too same problem, stil no working solution, what is the solution,,,,,,,,,,,,,,, http://forum.gsmhosting.com/vbb/f296...power-1266044/ |
05-14-2011, 19:04 | #14 (permalink) |
Member: 488536 Status: Offline Thanks Meter: 36 | ok, thanks midou01 ,your solution 100% working many many thanks br,,,,,, Use: InfinityUpdate_MModule_v3.62 1 repair security area 2 flash with ZTE-X670_32mb_ZTEMT25_09A_GEMINI_PCB01_GPRS_MT6225_S00 .X670_V1_OG_Z2_FRES_DFFA111_2010-05-14_En_Fr_Es_Orange-Lisbon.B0M.bin (tick smart write and format ffs) 3 unlock with smart fast |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
