12-10-2008, 14:49 | #31 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
12-27-2008, 07:12 | #32 (permalink) |
Banned Join Date: Sep 2008 Location: in ur dreams
Member: 867442 Status: Offline Sonork: 100.1602740 Thanks Meter: 143 | problem unlocking vodafone 226fm it unlocked when code entered 12345678 it is shows wrong code try243 min later but after 10 hrs problem is same |
The Following 2 Users Say Thank You to sanjayvikas For This Useful Post: |
12-27-2008, 09:20 | #37 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sanjayvikas You must download and use latest updates from support area ! DO NOT use half year old software ! You must check Infinity-Box support area at least two times per week due to Infinity-Box release new updates and support new models and features very fast. |
08-20-2010, 15:46 | #38 (permalink) |
Freak Poster Join Date: Nov 2009 Location: INDIA
Member: 1170625 Status: Offline Sonork: 100.1616527 Thanks Meter: 94 | Vodaphone 226fm successfully unlocked Vodaphone 226fm successfully unlocked Code: COM9 [VCP0] selected module v1.73 Device: Vodafone-226FM Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IH_180208_1259 180208_1259 EDI_IH Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20100820-195956.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20100820-195958.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20100820-200002.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20100820-200009.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 42 sec Remove/Install battery now ! |
The Following User Says Thank You to santhusystems For This Useful Post: |
after unlock vodafone 226 fm key pad not work ? | milandhal | Infinity-Box | 9 | 10-13-2009 09:00 |
vodafone 226 fm | mediapeople | ET-BoX | 1 | 01-15-2009 14:34 |
vodafone 226 fm sp unlock | rajendrakumar | Infinity-Box | 6 | 08-14-2008 08:30 |
Vodafone 226 Fm | That'sme | Infinity-Box | 1 | 07-21-2008 16:04 |
no code to enter in vodafone 226 fm . unlck done by using pinfinder | nazar2008 | Infinity-Box | 1 | 05-22-2008 15:20 |
