03-17-2009, 06:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 684454 Status: Offline Thanks Meter: 45 | w355 flashing problem here is log - COM3 [VCP0] selected Device: Motorola-W355 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... error: unexpected answer: error: can't load bootcode Connect Fail Finished, time used: 5 sec Remove/Install battery now ! |
03-18-2009, 18:32 | #2 (permalink) | |
05-23-2009, 14:12 | #3 (permalink) |
Freak Poster Join Date: May 2008 Location: india Age: 40
Member: 776810 Status: Offline Sonork: 100.1627706 Thanks Meter: 19 | same here w355 contact retailer problem in flasing....COM3 [VCP0] selected Device: Motorola-W355 Checking data, wait... connection mode: Standard connection Action: Flash write "smart write" enabled "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... error: unexpected answer: error: can't load bootcode Connect Fail Finished, time used: 27 sec Remove/Install battery now ! |
09-06-2009, 03:10 | #9 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Phone is dead here is the log; COM5 [VCP0] selected Device: Motorola-W355 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... error: unexpected answer: error: can't load bootcode Connect Fail Finished, time used: 5 sec Remove/Install battery now ! Need Help!!! |
09-07-2009, 02:41 | #11 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | Phone is dead here's the log; COM5 [VCP0] selected Device: Motorola-W355 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... error: unexpected answer: error: can't load bootcode Connect Fail Finished, time used: 5 sec Remove/Install battery now ! Need Help!!! |
09-07-2009, 17:45 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone is dead and can not be detected by software you need to desolder flash chip, program it with image file and solder flash chip back. Are you able to do so ? |
03-04-2010, 17:15 | #13 (permalink) |
Freak Poster Join Date: Jan 2008 Location: mumbai
Member: 680291 Status: Offline Thanks Meter: 21 | im flashing w355 showing this erro COM37 [VCP0] selected Device: Motorola-W355 Checking data, wait... connection mode: "Repair mode" connection Action: Flash write "smart write" enabled "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Write: FFS/File system Write: Eeprom error: no data for Flex/Customization plz help infinity |
03-07-2010, 14:20 | #14 (permalink) | |
Hi, What files you have loaded before flash operation ? | |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
w355 flashing problem | deepakgarg | Scout | 2 | 10-01-2009 07:37 |
w355 flashing problem | jitugrover | Infinity-Box | 3 | 09-08-2009 13:38 |
moto w355 flashing problem | N.I.T | Infinity-Box | 1 | 06-18-2009 09:06 |
26 Apr 2007: QCModule v1.10: w170, w355 flashing released and more... | InfinitySupport | Infinity-Box | 16 | 04-27-2007 12:04 |
