01-15-2007, 09:43 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, w375 repair is the same like c261, read this: http://forum.gsmhosting.com/vbb/showthread.php?t=364875 post log here to check. |
01-15-2007, 09:51 | #3 (permalink) |
No Life Poster Join Date: Oct 2004 Location: gsmworld Age: 43
Member: 85537 Status: Offline Thanks Meter: 66 | COM6 selected Action: unlock Flex file must be loaded before unlock operation. Please refer to unlock instruction/manual about more details. Do you want to continue and load Flex file now ? trying to load Flex file... Loading file v.02... W375_Flex_AT_007_retail[1].34F.bin Loaded Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 230400 Set Baud Done Check Flash-1... SW version: 0.0.62 HW version: MOTOROLA_H80S LP ver: 0062_001 Flex ver: FLEX_BJ_006 cpu id: 08B6 imei eeprom: 35300301140697 required SW version: 0.0.62 sp-locked: 23410. Check Flash-1 Done Check Flash-2... reading ... file saved: Backup_eeprom_calibration_35300301******_2007-1-15_11-22-52.34E.bin Err: this unit can't be unlocked, error#1 Check Flash-2 Fail Finished, time used: 30 sec Remove/Install battery now ! in support no flex file FLEX_BJ_006 |
01-15-2007, 10:15 | #4 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 40446 Status: Offline Thanks Meter: 6 | W375 NOT POSSIBLE UNLOCK W375 Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.62 HW version: MOTOROLA_H80S LP ver: 0062_007 Flex ver: FLEX_CK_005 cpu id: 08B6 imei eeprom: 35300301131665 required SW version: 0.0.62 sp-locked: 21803. Check Flash-1 Done Check Flash-2... reading ... file saved: Backup_eeprom_calibration_35300301131665_2007-1-15_10-11-54.34E.bin Err: this unit can't be unlocked, error#1 Check Flash-2 Fail |
01-15-2007, 10:22 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @mishiko_gsm why you ask for help if you think that you know good methods for w375 unlock ? flex for you (if you even can't understand how to repair your mistake): W375_Flex_BR_003_Locked_234-10.34F.bin @graca somebody asked you to post your logs here ? what is the reason you posted log ? |
01-15-2007, 10:27 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @all if you want to kill w375: write Flex file in it if you want to try to unlock w375: http://forum.gsmhosting.com/vbb/showthread.php?t=358366 if you want to repair w375(after stupid user's actions): http://forum.gsmhosting.com/vbb/showthread.php?t=364875 |
Motorola W375 restart with sim, & without sim ok | nakshatra | Infinity-Box | 8 | 12-11-2009 08:03 |
W375 Restart Problem!!! | Medusin | Infinity-Box | 11 | 10-06-2009 11:13 |
w375 restart | robean | Motorola ODM | 2 | 11-17-2008 13:45 |
pc restart when sending boots while unlock w375 | chris2007 | Smart-Clip | 3 | 08-27-2008 02:47 |
plz help.. w375 restart.... :( | wakuwaku | Smart-Clip | 2 | 02-06-2008 09:46 |
