Old 02-26-2009, 11:16   #1 (permalink)
ikram tabassum1's Avatar
Member: 681574
Sonork: 100.1614243
Thanks Meter: 138
kg 276 eeprom problem
kg 276 no service and following logs
COM6 [VCP0] selected
module v1.62
Device: LG-KG276
Checking data, wait...
Action: flash write
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL KG271 P16 92 V10d XXX-XX Jun 20 2007 +0
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-static_20090226-150828.B1E.bin
loading data...
data loaded
imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20090226-150829.B1E.bin
reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20090226-150836.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Erasing: Language Pack
Writing: Language Pack
Erasing: FFS-2/File system
Writing: FFS-2/File system
Write Done
Finished, time used: 412 sec
Remove/Install battery now !
Old 02-28-2009, 19:22   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You can try to flash phone with KG275 repair eeprom and then make "sp-unlock" operation.
Old 03-02-2009, 13:36   #3 (permalink)
Member: 681574
Sonork: 100.1614243
Thanks Meter: 138
Sir i try to repair kg275 eeprom and unlock but phone is blinking i try to rest setting but blinking
Old 03-02-2009, 14:48   #4 (permalink)
Member: 130995
Hello,
Make "sp-unlock" with method #2 (Airtel etc.)
Old 03-02-2009, 16:47   #5 (permalink)
Member: 681574
Sonork: 100.1614243
Thanks Meter: 138
yes sir i make unlock method #2 and then reset setting
eeprom is ok signal is ok but another problem full charged battery phone show low battery and out of batter
after write eeprom no battery problem?
Old 03-02-2009, 18:23   #6 (permalink)
Member: 130995
Try to use other repair eeprom file.
Old 03-04-2009, 21:53   #7 (permalink)
Member: 986684
Sonork: lock
Thanks Meter: 11
hi dear i i makeing is lote lg brand set but sorry i dont nderstand
waht there is it.s a problm please again i repet you if have your cellphone
signal trobil so you can make it's try full flish frist munall code 2945#*#
another singal is trobil so you chang is rf if will be trobill when flish is infrdy box
thankx
Old 03-04-2009, 21:56   #8 (permalink)
Member: 986684
Sonork: lock
Thanks Meter: 11
hi dear youdont know it;s all mosel is samebord here for exampill kg 270 276 so you frist flish is munalwhen i send allthe matha don;t warrey be brother
thankx
Old 09-29-2009, 22:00   #9 (permalink)
jufong's Avatar
Member: 120908
Thanks Meter: 38
yes for yor solutiont
phone can fix but batery problem
thanks for infinity suport
Old 10-12-2009, 19:22   #10 (permalink)
Member: 321173
Originally Posted by infinitysupport View Post
hello,
make "sp-unlock" with method #2 (airtel etc.)
ver very thanks infinety team i have solved my blinking lg kg 276 problom
thanks for it
Old 01-26-2011, 06:16   #11 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,017
COM2 [VCP3] selected
module v1.78
Device: LG-KG276
Action: "sp-unlock"
direct unlock method #2 (Airtel etc.)
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
sw version: .00 ULC2GL CIS Open KG276 P16 07 V10b XXX-XX AUG 13 2007 +0
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-static_20110126-060502.B1E.bin
loading data...
data loaded
imei: 0Q@00¶200Ì0P0œ@00
reading eeprom-security_0Q@00¶200Ì0P0œ@00...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-security_0Q@00¶200Ì0P0œ@00_20110126-060503.B1E.bin
reading eeprom-complete_0Q@00¶200Ì0P0œ@00...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_0Q@00¶200Ì0P0œ@00_20110126-060510.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-security
Writing: eeprom-security
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 32 sec
my problemes solved
thanks infinitiy team
The Following User Says Thank You to DHEERAJ_SHARMA For This Useful Post:
Old 01-26-2011, 06:17   #12 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,017
Originally Posted by InfinitySupport View Post
Hello,
a realy best.............
Old 01-26-2011, 08:21   #13 (permalink)
Member: 130995
module v1.78
Device: LG-KG276
Action: "sp-unlock"
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
Check memory Done
Write ...
Write Done
my problemes solved
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
kg 276 sim card error madho LG Hardware Repair 4 10-13-2011 07:25
kg 276 problem deepaksawdia Infinity-Box 2 08-15-2009 20:39
KG 270 eeprom problem ? aminnovelty Infinity-Box 1 08-11-2009 22:53
kg 276 mediapeople Infinity-Box 0 07-18-2008 12:12
KG 276 CANT BOOT ON UFS+hwk kashif-ch LG 3 05-14-2008 10:40
Page generated in 0.24168 seconds with 9 queries
