Old 02-25-2016, 19:16   #1 (permalink)
Member: 1471997
Thanks Meter: 22
Getting error in reading firmware...
Operation : Read Flash [ v1.41 ]
Wait for phone...
Phone found! [ 345 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 002C00440044004B00A9000000000000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:13
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 54 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x004E , [MICRON] MT29F32G08CBADB
[NAND] : FLASH_DIE : 002C 0044 0044 004B 00A9 0000 0000
[NAND] : FLASH_LEN : 0x100000000
[NAND] : FLASH_EXT : 2000/0100/00/
DEV RID : 1D9F981AFCB91F1F0A6E03CCCA1AEA95
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Error while reading initial info! First make sure about "ReadInfo" passed fully!
Operation Failed
Elapsed: 00:00:13
Old 02-26-2016, 07:32   #2 (permalink)
mquimpanes's Avatar
Member: 765233
Sonork: 100.1664273
Thanks Meter: 107
read info first
Old 02-26-2016, 07:33   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Check Nand Extra option (Infront of Read Firmware button) and then read factory firmware.
Or read info successfully first by changing Nand Init mode from Settings-SP:Other-Nand Init Mode.
Br.
Infinity Box Support Team.
Old 03-17-2017, 06:35   #4 (permalink)
.::RONY::.'s Avatar
Member: 1104393
Sonork: 100.1603062 .::RONY::..
Thanks Meter: 130
yes i change
work for me...........
Page generated in 0.13403 seconds with 9 queries
