Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 11-11-2014, 07:53   #1 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
how flash nokia asha 503 RM-920
hi
ii want to know if someone succed the flash of asha 503 RM-920 , i try with best, hwk, advance but none. need help. thk
Old 11-11-2014, 08:31   #2 (permalink)
LOKEMUNFU's Avatar
Member: 2100013
Thanks Meter: 125
Originally Posted by roni2 View Post
hi
Index of pub/software/Drivers/
Install WinUSB
Nokia Connectivity 7.1.182.0
Try.............
Old 11-11-2014, 14:26   #3 (permalink)
cheyn's Avatar
Member: 646368
Thanks Meter: 113
SIMILAR PROBLEM,cannot connect the phone to the computer properly,it connects for a second and the phone restarts with charging.
installed Nokia Connectivity 7.1.182.0 and its restarting with charge.
cannot connect with NCS.
Old 11-11-2014, 14:50   #4 (permalink)
LOKEMUNFU's Avatar
Member: 2100013
Thanks Meter: 125
Please install Nokia PC Suite
The Following User Says Thank You to LOKEMUNFU For This Useful Post:
Old 11-13-2014, 10:54   #5 (permalink)
cheyn's Avatar
Member: 646368
Thanks Meter: 113
i installed nokia pc suite,i suppose pc suite is not compatible with asha phones.it is still not working,connect flash mode and phone start with charge.
i am using xp sp3.
please guide with how to install drivers correctly or there is a way to do dead flash differently with NCS.
Old 11-13-2014, 13:48   #6 (permalink)
LOKEMUNFU's Avatar
Member: 2100013
Thanks Meter: 125
FLASHING TOOL there are many, you may not need to use the NCS, you can choose to use the Phoenix cracked version because support WIN XP.
RM is what ? I can help you search for a version that supports it Phoenix
Old 11-13-2014, 22:27   #7 (permalink)
cheyn's Avatar
Member: 646368
Thanks Meter: 113
Thanks for reply, appreciate your assistance.just to avoid confusion..latest asha s does not use phoenix ,nokia released NCS.for nok 503 NCS V5-1414 and above release.
My question is why am i strughling to connect only nok asha 503 to flash with ncs.i have flashed many windows and bb5 without any struggle.
I have also tried on windows 7 machine and nok 503 fails to flash in dead mode.
Old 11-14-2014, 04:25   #8 (permalink)
LOKEMUNFU's Avatar
Member: 2100013
Thanks Meter: 125
Although I did not go to test this model
But I can tell you really be able to use the cracked version of Phoenix
In Phoenix.ini manually add models
About NCS Why not use DEAD MODE
No Comment
Old 10-31-2015, 17:15   #9 (permalink)
Member: 1712857
with best download Nokia_WP8x_NXP_MTKx_Asha drivers from support then install, then connect the phone without battery until best detects , it will show u that connect battery after detected then ur gud to go!
Page generated in 0.18773 seconds with 8 queries
