locked memory card i entered a password in my memory card. now am not able to access the memory card? pls someone can tell me how can i get back the data it is very imp. the phone model is nokia 6280.... Please someone help me. |
1 Attachment(s) try this maybe work with you wbr |
thanks for the tool but tht didn't work... thanks for your help... |
it`s not mmc it`s a micro sd card |
memory card unlocker use memory card unlocker it's work 100% |
use FE explore software ...install it in handset.........goto on C:,system>mmcstore. send this file to PC via blue tooth and open it using notepad ....see the password... wbr... |
the chance of unlock micro sd is 20% ... try memory unlocker or use 9v battry and connect with micro sd las and frist pin !!! try and post it |
same problem here wid nokia 6270 i've tryed wid mmc unlocker and JAF unlocker as well but still same plez help me |
all you need is a software that recover lost file or deleted file. but you can't access your mmc because of the password. remove the password first.... |
i'm having the same problem with Nokia 6270. Please help. use FE explore software ...install it in handset.........goto on C:,system>mmcstore. send this file to PC via blue tooth and open it using notepad ....see the password... wbr... I have tried using Fexplorer since my phone is a series 40 phone i cant install sis file so i tried with the java version, and i can only access gallery in the c: drive |
just insert the card into any n80 or n73 and format it works 100% br btl |
try this http://www.thc.org/thc-nokia-unlock it might help |
hey it works! :D at first it wasnt working..but maybe thats because i put the wrong password alot of times..so wat i did was take the mmc out of the phone, restart the phone, then put it back in and unlock it from the mmc app tht comes with the phone.. thanx mate :) good job! |
Micro SD Unlock Quote:
About putting the momery in a Nokia N73, or N80, or N95, or E65, you can unlock the memory directly by formatting it... It works 1000000% ;) |
