Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-22-2006, 18:19   #1 (permalink)
Member: 372381
Question locked memory card
i entered a password in my memory card. now am not able to access the memory card? pls someone can tell me how can i get back the data it is very imp. the phone model is nokia 6280....
Please someone help me.
Old 10-22-2006, 18:38   #2 (permalink)
.:LOCK UNLOCK:.'s Avatar
Member: 236771
Thanks Meter: 40
try this maybe work with you
wbr
The Following 12 Users Say Thank You to .:LOCK UNLOCK:. For This Useful Post:
Old 10-23-2006, 05:00   #3 (permalink)
Member: 372381
thanks for the tool but tht didn't work... thanks for your help...
Old 10-23-2006, 08:34   #4 (permalink)
Member: 50261
it`s not mmc it`s a micro sd card
Old 10-23-2006, 09:27   #5 (permalink)
Member: 67260
Thanks Meter: 146
memory card unlocker
use memory card unlocker it's work 100%
Old 10-23-2006, 09:29   #6 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
use FE explore software ...install it in handset.........goto on C:,system>mmcstore.
send this file to PC via blue tooth and open it using notepad ....see the password...
wbr...
The Following User Says Thank You to ..:MumbaiGsm:.. For This Useful Post:
Old 10-23-2006, 16:31   #7 (permalink)
Member: 224680
Thanks Meter: 72
the chance of unlock micro sd is 20% ... try memory unlocker or use 9v battry and connect with micro sd las and frist pin !!!
try and post it
Old 10-23-2006, 20:06   #8 (permalink)
Member: 292887
Lightbulb
same problem here wid nokia 6270 i've tryed wid mmc unlocker and JAF unlocker as well but still same plez help me
Old 10-24-2006, 02:01   #9 (permalink)
Member: 44950
Thanks Meter: 10
all you need is a software that recover lost file or deleted file. but you can't access your mmc because of the password. remove the password first....
The Following User Says Thank You to robz For This Useful Post:
Old 12-09-2006, 20:07   #10 (permalink)
Member: 380109
Thanks Meter: 3
i'm having the same problem with Nokia 6270. Please help.
wbr...
I have tried using Fexplorer since my phone is a series 40 phone i cant install sis file so i tried with the java version, and i can only access gallery in the c: drive
The Following User Says Thank You to valtea For This Useful Post:
Old 12-10-2006, 16:37   #11 (permalink)
btl
btl's Avatar
Member: 50389
Thanks Meter: 36
just insert the card into any n80 or n73 and format it works 100%
br
btl
The Following User Says Thank You to btl For This Useful Post:
Old 12-10-2006, 23:46   #12 (permalink)
Member: 408147
Thanks Meter: 6
try this http://www.thc.org/thc-nokia-unlock
it might help
The Following 6 Users Say Thank You to bearneb For This Useful Post:
Old 12-15-2006, 11:15   #13 (permalink)
Member: 162211
hey it works!
at first it wasnt working..but maybe thats because i put the wrong password alot of times..so wat i did was take the mmc out of the phone, restart the phone, then put it back in and unlock it from the mmc app tht comes with the phone..
thanx mate good job!
The Following User Says Thank You to dying_soul For This Useful Post:
Old 04-24-2008, 08:55   #14 (permalink)
Member: 461923
Thanks Meter: 2,020
br
btl
..yes tested this way..work good...
The Following User Says Thank You to stefani For This Useful Post:
Old 06-05-2008, 19:34   #15 (permalink)
Member: 483230
Thanks Meter: 25
Wink Micro SD Unlock
Originally Posted by bearneb View Post
This solution is ONLY to unlock a symbian based Nokia cellphone, we are talking about MICRO SD UNLOCK...
About putting the momery in a Nokia N73, or N80, or N95, or E65, you can unlock the memory directly by formatting it... It works 1000000%
The Following 2 Users Say Thank You to <DJ-JaaM-> For This Useful Post:
<< Nokia E90 Exclusive Feature : Unlock locked Memory Card >> zeel_zeel Nokia Base Band 5 ( BB-5 ) 9 09-05-2008 07:13
Locked Memory Card in 6500 Slide mikwillo Nokia Base Band 5 ( BB-5 ) 5 05-09-2008 13:59
Locked Memory Card mld_n73 Nokia Multimedia 2 07-09-2007 16:34
how to unlock a locked memory card zenqd Nokia Multimedia 5 04-25-2005 14:11
3650 Memory Card locked, please help me! hoang WD2 & APE (Symbian Phones) 11 11-12-2003 22:09
Page generated in 0.26714 seconds with 10 queries
